04-17-2018 07:05
04-17-2018 07:05
I changed out my versa yesterday in the middle of doing an activity. I had active minutes with my charge 2 up until I changed it out for the versa and have not had active minutes since, even with same activities. Anyone else having this same problem?
10-18-2018 03:38
10-18-2018 03:38
My versa has not recorded any active minutes since Saturday. That's 6 days. Please help its most frustrating!! Saturday is the day I moved house and I'm trying see how my stats have changed since the move... but nothing logged!!
02-04-2019 19:03
02-04-2019 19:03
Did you ever get this issue resolved? My Versa is doing the same thing.
02-04-2019 20:34
02-04-2019 20:34
Best Answer02-25-2019 10:54
02-25-2019 10:54
Mine is also doing this. I ran 8 miles yesterday. It showed over 100 active minutes and then went down to zero, even with 26,000 steps. My HR function also quit working.
Best Answer04-29-2019 12:03
04-29-2019 12:03
Did this issue ever resolve for you? I ran 8 miles today and my active minutes are zero, and my calorie burn at 3pm is 700, when it shows me I burned more than that when I click on the “run” under workouts. Shows zero active minutes on both watch and phone.
Best Answer04-29-2019 12:11
04-29-2019 12:11
Best Answer06-04-2019 11:49
06-04-2019 11:49
I'm also having this issue. About a week ago it showed my active minutes, then I put in my work out and it went to zero and hasn't recorded my active minutes since. What's happening? What should I do?
Best Answer06-04-2019 15:42
06-04-2019 15:42
Best Answer06-24-2019 21:08
06-24-2019 21:08
My tracker is till not working even after th update. Can someone help please.
Best Answer07-09-2019 17:09
07-09-2019 17:09
I would like to try this but how do I update the app?
Best Answer07-23-2019 09:14
07-23-2019 09:14
I’m having the same problem. Replaced my charge 2 with the versa lite yesterday and won’t record active minutes. What did you do to resolve this. ?
Ive done a reset and updated the app.
Best Answer07-23-2019 10:36
07-23-2019 10:36
Best Answer07-30-2019 18:12
07-30-2019 18:12
I have this same problem and looking on this site it appears that Fitbit doesn't care. It is frustrating because it can go for days and it works perfectly and then comes a day that I go hiking for miles with it recording HR, Steps, Elevation changes (floors) and Exercise for the day, but it doesn't record active minutes. Will Fitbit ever fix this?
Best Answer07-31-2019 04:17 - edited 07-31-2019 04:18
I’ve only had the versa lite for 1 week and I’ve been in contact with Fitbit every day. I’ve not found them that helpful at all. And every time I mention the 2 year warranty they just ignore it.
They like to try and blame it on user error.
Its just started working properly in the last day or so after I actually turned the watch off then back on. Fingers crossed it’s ok now.
I never had any issues with my charge and charge 2.
Its all very frustrating
Best Answer09-11-2019 13:42
09-11-2019 13:42
Why is my versa lite not recording active minutes today but has been previously.
Best Answer09-11-2019 16:24
09-11-2019 16:24
Versa lite stopped syncing my active minutes today. Did sync Sunday, Monday and Tuesday. How is this fixed?
Best Answer09-11-2019 16:39
09-11-2019 16:39
I don't have the Versa Lite, but with my Versa restarting it did help.
Best Answer06-01-2020 08:28
06-01-2020 08:28
My fit fit suddenly stopped recording active minutes
Best Answer06-05-2020 19:22
06-05-2020 19:22
Best Answer06-24-2020 14:46
06-24-2020 14:46
I’ve seen others having a syncing issue. How do you update the app to fix this
