Versa not recording heart rate
Hi,
My Fitbit Versa is not recording my heart rate, and the green light at the back is not even lighting up.
I went for a swim yesterday, after I rinsed it and left it hanging to dry as I have been doing all summer and it was okay. Some time later it seems to have stopped working. Since then I have gone into settings and turned the heart rate off and back on, and even restarted the device but still nothing.
Tried charging it for a bit (even though there was sufficient battery), but not even this worked.
Any idea how to solve this please??
Cheers!
5 REPLIES 5
Try resetting versa to factory defaults. Just sync it first as the hard reset will wipe it. I'm afraid tho that sensor got water damaged (yes, I am aware versa is supposed to be swimproof).
Marrrmaduke | Canada
Charge HR, Blaze, Charge 2, Charge 3, Inspire HR, Versa Lite, Versa SE, Aria
I agree with @Marrrmaduke. Try a Factory reset (settings app on the watch and scroll down to About). If that doesnt fix it, contact Support (link in my signature)
Community Council Member
Helen | Western Australia
So will the sensor work again then? Or not?!
Thanks @Marrrmaduke and @NellyG for your replies, unfortunately still unsuccessful here.
I turned the heart rate on and off, switched my versa off, did a hard reset ... None of these worked for me. I have now emailed support. Hoping i’ll get a solution asap
Good luck! Hopefully your versa will get replaced soon.😊
