07-02-2018 11:46 - last edited on 07-04-2018 04:56 by AlvaroFitbit
My Versa would not sync with my phone app or pc account, messaged Fitbit customer service who went through all of the troubleshooting again with me (I had already done this) and it still didn't work. Was then advised to do a Factory Reset which I said I would do once I had time as they have you on forever doing this and that...so, I have done a factory reset and now my watch is just showing the Fitbit logo and telling me to install the app. I have uninstalled and reinstalled the app on my phone and it brings up my usual account but the watch is still showing Fitbit logo. When I go to add a 'new device' to the app it cannot find my watch. I'm losing faith in this watch now and I am not happy at all, I've had it since May and it's been fine up until a few days ago. The message service seems closed now and now I have no watch and a useless app.
09-30-2020 15:15
09-30-2020 15:15
Same thing happened to me. When I contacted Fitbit they said I’m out of warranty but they can send me 35% off to replace. What the **ahem**, the software is what ruined it. It was working fine, charging fine until accidental factory reset!
10-22-2020 13:03
10-22-2020 13:03
Hi Alvaro,
I've completed these steps numerous times, and am in factory re-set mode. Now, when it asks for the four digit number code on the watch, the numbers flash for a second, I enter them on the watch, and it fails to connect. Power is full. The tracker is being found, but cannot complete the connection process. Please advise what the next steps are.
10-22-2020 13:04
10-22-2020 13:04
that's not encouraging. What number did you call?
10-22-2020 13:14 - last edited on 10-22-2020 16:44 by LiliyaFitbit
I didn’t call; I contacted the help online.
11-18-2020 00:58
11-18-2020 00:58
Same has happened to me trying to turn on now hope it works 🙂
01-03-2021 10:35
01-03-2021 10:35
So after reading all this I hope this helps someone....I had to register on here and let you all know what worked for me. I know someone else will have this issue at some point.
I did a factory reset and it would not reconnect, I had to scroll down and connect as just a normal "Versa" watch. NOT "Versa 2"!!!
When connecting to your watch, scroll down a little bit past where it says Versa 2 and you'll see Versa Lite and then just Versa. USE THAT, DONT USE VERSA 2!!!!! Use just plain old "Versa" to connect. You have to scroll down the list of devices to see it. Connect with just "Versa" and leave it for a few seconds. Then it will update and everything over WiFi. Seems to be all good now!
I was messing with this for 2 hours, factory resets, rebooting, etc etc. I went to Versa after reading someone else did it and it worked first try. I dont think it was a coincidence. Again, I saw this worked for someone else and I tried it. It makes sense also if the watch is so old maybe its on older software when we do a factory reset and there is some weird compatability issue. Either way give it a try. I hope it works for you guys. The watch is great I love it but this issue can get people to throw it right in the garbage and thats not good.
01-05-2021 04:59
01-05-2021 04:59
02-04-2021 15:23
02-04-2021 15:23
Same problem here. Did you get the problem resolved? If so, How? So frustrated!!!
07-21-2021 23:42
07-21-2021 23:42
Can someone please help???
I have the same problem as disey43 - I read the answers but my Versa 3 is telling me to install the Fitbit App and my Fitbit app is telling me it can find the Versa 3.
I did all the trouble shooting and since the factory reset I can do nothing .... HELP!!!!
07-22-2021 07:17
07-22-2021 07:17
07-22-2021 12:27
07-22-2021 12:27
Hi .
I did mine through my computer as I needed to do the update and it wouldn't do it through the app
07-22-2021 12:49
07-22-2021 12:49
Hey! I have been fighting with my versa 2 since last night. I noticed the watch offers way more than my current version did. My watch has not updated since the day I bought it in 2018!! I did the factory reset and have had no luck getting it to connect again to my phone. I read a review above that said to scroll down and connect as "Versa" instead of "Versa 2" when setting up as new device and it FINALLY worked!!! Super aggravating, I was ready to throw the watch away and find a new company.
07-22-2021 12:57
07-22-2021 12:57
07-22-2021 16:07
07-22-2021 16:07
07-25-2021 19:05
07-25-2021 19:05
Same here I’m to the point where I just want to give up on it
09-25-2021 00:26
09-25-2021 00:26
Same here. Fitbit is just full of hardware features but no reliability on software. Not worth it really.
09-26-2021 06:22
09-26-2021 06:22
08-30-2022 09:31
08-30-2022 09:31
The solution was so simple I did huge struggle to find out the cause. I was facing the same issue as all others. The watch was keep restarting after the factory reset and unable to connect to the mobile. I was selecting Versa 2, but the watch was Versa Lite.
Immediately after selecting the correct model of the watch from the Fitbit app, the mobile immediately found the watch nearby and started updating it.
This is a fault of Fitbit that is not able to recognize the model of the watch by itself and asking from the user to select it.
You can follow the suggestion mentioned by me to fix the issue.
02-16-2023 08:33
02-16-2023 08:33
Hi this happened to me and the watch won’t switch on
