09-23-2018 18:21
09-23-2018 18:21
About two days ago my versa has stopped calculating active minutes.all exercises have been over twenty minutes but isn't registering in active minutes but shows in my exercise goals
09-23-2018 19:30
09-23-2018 19:30
Have you tried resetting the Fitbit?
09-24-2018 12:40 - edited 09-24-2018 12:42
Hey @Spinnerella, welcome aboard! Since active minutes are related with your heart rate, I'd like you to tell me if your Versa has been accurately recording your BPM. In addition, I'd like you to review our wearing tips, specially if you are exercising. If everything is fine with the heart rate monitor on your Versa, please note that, if you experiencing an inconsistency with active minutes, let me explain to you that our algorithms detect subtle differences in exertion that may explain why two seemingly identical activities result in different active minute totals. For example if you took a brisk walk along the same route two days in a row, differences in your speed and exertion levels (e.g. out of breath vs not out of breath, etc) will cause different active minute totals for the two activities. Also keep in mind that active minutes are only recorded for activities that last 10 minutes or longer.
Because our trackers primarily track movement through the use of an accelerometer, they more accurately detect active minutes for step-based activities (brisk walking, running) than non-step based activities or activities that require more than steps (yoga, tennis).
For further information about active minutes, please take a look at this help article.
Hope this helps! Let me know how it goes!
01-09-2019 16:26
01-09-2019 16:26
Mine is counting them in the app but I can’t access from my Versa like I could with my Charge 2. I thought it was showing me last week but I could be wrong. Did you fix this, and if so, can you see them on your tracker?
01-14-2019 02:02
01-14-2019 02:02
This problem only started after i got a flash uodate for the watch. On too of that the flash also mucked up tge versa ability to display txt messages and incoming calls.
Sorry but what they are saying makes no sense. If your heart is elevated and you are involved in movement that is an active minute. So what they are saying is rhe watxh will wait 10.minutes to decide if you are being active? Garbage its a bug fix it!
01-21-2019 07:07
01-21-2019 07:07
Hey @Steph_110, I hope you are doin' fine! Swipe up from the clock face on your watch to access Fitbit Today, which tracks up to 7 stats. Among them, you can see this:
- Steps taken today, calories burned, distance covered, floors climbed, active minutes, and goal history over the past 7 days.
@Bungobuns, welcome aboard! Your Versa will start counting active minutes after 10 minutes of moderate to intense activity. Less that that, it will not do that. Now in regards of the text and call notifications, I'd like you to take a look at the troubleshooting in this help article: My Fitbit device isn't receiving notifications.
01-21-2019 12:06
01-21-2019 12:06
01-22-2019 08:31
01-22-2019 08:31
Thanks for your answer @Steph_110! Let me see if I understood. So you don't want that all your stats show on the display on your Versa, right? You'd like to get, as the main stats, active minutes, is that correct? If so, I could suggest you to reorder the tiles. To do this, press and hold a row, then drag it up or down to change its position. Then you'll see those that are more important to you, at the beginning.
Keep me posted if you have further questions!
01-22-2019 12:38
01-22-2019 12:38
