01-28-2019 04:00
01-28-2019 04:00
my versa is not showing the calories burned in the exercise part of the dashboard.
It just appears with a line
I have reset the watch. Downloaded the app again and checked all my syncing and this is still not showing.
This is a very important feature i need to see and it is not showing.
Is there.an issue with the app because if not i will be returning the watch as this is a major fault
01-28-2019 04:23
01-28-2019 04:23
This seems to be a long running issue that fitbit are aware of. As I understand it the calories will show if you select the exercise to go into the detail, but will not show on the summary.
Have a look at the following which is the main thread on this subject and has some updates from fitbit:
01-28-2019 17:51
01-28-2019 17:51
Thankyou for your reply Steve.
I have read all the forums about this issue and it seems to be a problem with the App.
This really isnt good enough from Fitbit. You would think they would have a successful app running for the amount of products they have.
I think i will take it back and go with another fitness tracker.
