09-26-2018
08:19
06:22
AlejandraFitbit
09-26-2018
08:19
06:22
AlejandraFitbit
I am thinking I missed a setting somewhere. Because since I got this replacement and it's been updated, it seems any text messages, I get will only give me the options of Open (open text message app on my phone so I can reply) or Close (actually dismisses the text on the tracker).
I don't have the option to quick reply, although I did at one point less than a month ago before I got my replacement. Any ideas anyone please? If it means anything, I am and have been using Textra with no issues until now. Thanks for any help.
04-02-2019 13:10
04-02-2019 13:10
@Vstanto1 For Button 2 choose "Android In line Reply" not "Quick Reply"
04-02-2019 13:11
04-02-2019 13:11
You seem to be on the right path. Not sure what else to change. But let me ask, what do you have under Customize Notifications-Heads up Notifications-Style when Unlocked....
Mines is set to Android Heads up
04-02-2019 13:14
04-02-2019 13:14
Lol yep you are correct, didn't see that one error. You definitely helped me when I had this problem!
04-02-2019 13:17
04-02-2019 13:17
04-02-2019 13:18
04-02-2019 13:18
Follow @kcronin post above to get it right. She found your error when I totally missed it.
08-05-2019 10:25
08-05-2019 10:25
I have just purchased fitbit versa lite and all the setting is fine and the quick reply doesn’t work. Whats the solution? I am not using the textra app..
08-05-2019 11:41
08-05-2019 11:41
08-05-2019 13:37
08-05-2019 13:37
Its so sad that mine is still not working considering i have a new phone iphone 8 plus, i have also joined a few fitbit community. And still is not working 😞
08-05-2019 13:40
08-05-2019 13:40
Quick Replies DO NOT currently work for IPhone at this time. You can receive messages but cannot reply to them.
08-05-2019 13:41
08-05-2019 13:41
@Malaki Quick Replies won't work with Apple phones. Apple won't allow it. Only Android phones running Android 7 or higher can use Quick Replies.
08-05-2019 13:42
08-05-2019 13:42
Oh i see. Thank you so much
08-27-2019 17:00
08-27-2019 17:00
My Terra app doesn't have a Android in line to use in second button?
08-27-2019 17:15
08-27-2019 17:15
@Lisab0878 What phone do you have and what operating system is your phone running. If you are Android, you need at least Android 7.0 to be able to use the Quick Reply option. Not having the In-Line reply option suggests that your phone might not be running Android 7.0.
08-27-2019 18:22
08-27-2019 18:22
09-28-2019 13:47
09-28-2019 13:47
I have a samsung 9+ and versa. I used to get message notifications on my versa using textra and the quick reply option was working. I am no longer getting any message notifications on my versa. I already have the textra app set up with the customized notifications mentioned. I even unsynced my versa and resynced it as well as restarted my phone. I get other notifications like phone calls without any issues.
Any suggestions?
10-15-2019 10:52
10-15-2019 10:52
Hi. Can you maybe help me please I have an IphoneX and Fitbit Versa with the last update i can recieve notifications on my watch but i don’t have the option to reply. All the notifications come in .. do i miss something?
10-15-2019 11:32
10-15-2019 11:32
Help I have the same problem i don’t see the quick reply option.
I have an Iphone X and fitbit vesa I see all notifications but i can not reply.
somebody know what do i miss it should work ..
10-15-2019 11:48
10-15-2019 11:48
@SunsetRunner Quick Reply is not an option for iPhone. Apple will not allow it to happen.
10-15-2019 12:05
10-15-2019 12:05
10-15-2019 12:28
10-15-2019 12:28
it is actuay very strange because in the description it standa very clear that it can be used also from Iphone. I look just on the app in itselff and it actually stands very clear that it works. Why then it is this confusion?
