05-04-2019 02:49
05-04-2019 02:49
When you open the Today app on the Versa (slide up from clock face) you can scroll all the way to the bottom and touch on Settings. There you can choose 7 elements. Sleep is NOT one of the available elements. How do I fix this?
Steps already taken are as follows
Reset versa to factory default still not showing
Updated versa and the fitbit app then restarted the fit bit still not showing
Help please this is annoying
05-04-2019 13:11
05-04-2019 13:11
Hi, this is weird. Try this: go to Apps in the Fitbit app by pressing the watch icon in the dashboard of your Fitbit app. Within "My apps", see if there is a settings icon right next to the Today screen. If this is present, press it and update the Today screen. Hope this helps.
