10-05-2018
16:30
07:46
MarcoGFitbit
10-05-2018
16:30
07:46
MarcoGFitbit
How can I get Versa to show the date? It was fine until I returned from Europe. Now it shows the correct time but no date.
Best Answer10-06-2018 07:49
10-06-2018 07:49
Hello @frcreed, thanks for joining the Fitbit Community, it's great to have you on board. ![]()
I appreciate your participation in the Forums and for having shared your experience with us. At this moment I would like to gather some information from you so I can check this further:
This information will be very helpful for me, if you have any other details you'd like to share please do, they will be helpful as well.
Thanks for your patience and understanding, I'll be waiting to hear from you.
09:51
05:28
YojanaFitbit
10-06-2018
09:51
05:28
YojanaFitbit
Thanks so much for your response. After several hours the correct date appeared; before it showed no date at all - just blank spaces where the number should be. So I'm good now. My best guess is that the watch was trying to access the wrong internet connection here at home. In any event, thanks for writing; sorry to have bothered you.
Best Answer10-07-2018 12:20
10-07-2018 12:20
My wife and I both have versa and the date does not show on either one .The date shows as --/--/-- on all watch faces.
10-07-2018 13:42
10-07-2018 13:42
Ultimately my date showed up. The best I could figure is that my Versa had been accessing the wrong internet site at our home. I'm really not sure, so I can't offer any solution for you. I wish you well ... and thanks for posting.
Best Answer10-08-2018 09:25
10-08-2018 09:25
Best Answer10-23-2018 12:06
10-23-2018 12:06
My versa no longer shows the date or any info other than the time, temperature, and heart rate (current and resting). I’ve synced it and reset it multiple times with no change. Any solutions?
Best Answer10-23-2018 13:51
10-23-2018 13:51
Best Answer10-25-2018 07:15
10-25-2018 07:15
Hello everyone, I hope you're doing well. ![]()
@frcreed and @cliffbutler, I appreciate you have come back and let us know your issue has now been resolved, I'm very glad.
@codmcshizz1, thanks for reporting this issue to us, as you have already synced and reset your Versa multiple times, I would like to know which clock-face are you currently using. In the meantime, please change to a different one (preferably a Fitbit clock-face), then sync your Versa, after that, change the clock-face to the one you're currently using and check if this solves the issue.
