02-11-2019 12:06
02-11-2019 12:06
Dear community,
My fitbit Versa does not show weather on the screen. Instead it says - "Sync the Fitbit mobile app to update" . I have updated multiple times but it's still the same message.
Am I missing out on something? my Versa is connected through IPhone and I use the inbuilt weather app on my phone.
Your help is welcomed.
Thanks,
Priyanka
02-11-2019 14:51
02-11-2019 14:51
Hi, are you using another Clock Face than one of Fitbit itself? If yes, I would like to suggest two things:
1. Install a Clock Face made by Fitbit itself.
2. If you're using a Third Party clock face, would you be so kind to send me the name of it?
02-11-2019 14:59
02-11-2019 14:59
Thanks for responding Kuzibri.
I am using clock named "Coalfaxness" designed by "dezign999".
I just synced and clock face still says - "fetching".
02-11-2019 15:08 - edited 02-11-2019 15:16
Where did you get this Watch Face from? Cannot find it it "All Clocks" after typing in the name of the Face or the Developer?
Edit: found it, it's called Colfaxness!!
02-11-2019 15:22
02-11-2019 15:22
Hi, read my post about your Clock face. The reason why your weather is not showing in this Clock face because it uses a different provider that Fitbit does. Your clock face uses Gregoiresage as a provider whilst Fitbit uses AccuWeather. that's the reason of your problem. So the only solution is either to find a Third Party Clock Face that uses the same provider or one of Fitbit itself. In the last case I'm afraid they will not show the weather, but this is a matter of trial and error!
02-12-2019 06:40
02-12-2019 06:40
Thank you Kuzibri for your in-depth analysis.
Do you have any recommendation for a (free) clock face to get what I am seeking?
Thanks.
12-24-2019 06:24
12-24-2019 06:24
Hello, I have updated my Versa 2 and having the same issue. Went through the notification updates and steps and that is working fine but weather is not telling me to sync. I have synced many many many times and also restarted the Fitbit and reset the WiFi many times. It was working but stopped two days ago. I verified blue tooth works too plus using the original watch face from Fitbit. Now what???
