Versa not syncing swim times/distance properly
Hi, has anybody else had any issues with their logged swim sessions in the Fitbit app?
I have the original Versa and recently I’ve noticed that the times and distances are weird after syncing to the app. On the watch itself they are fine
for example, I swim 100m free in about 1.35 but once synced it says 1500/100m. This is also messing up my distances. The example attached should have a total distance of 3275m
any ideas?
I’ve updated the software and tried updating/deleting and reinstalling the app.
TIA
1 REPLY 1
Forse ho risolto: facendo così sono riuscita a correggere in modo permanente i dati sulla App Fitbit Mobile:
1) scaricato dashboard Fitbit sul PC
2) in allenamento nuoto, corretto la distanza sbagliata e salvato
3) sincronizzato con Fitbit Mobile
Resta ancora da verificare con il prossimo allenamento:
1) sincronizzare il Fitbit Versa con il PC così da avere i dati giusti sulla dashboard
2) sincronizzare l'App Mobile con il PC
