08-26-2018 17:11
08-26-2018 17:11
I got my Versa set up last night, after multiple times of it failing but now today it will not sync at all. It's so frustrating. I went to the compatiblilty link and my device is not listed at all. Does that mean not compatible? The words on the link say something like find your phone to see which things were compatible so I assumed it would tell me if it's not.... But maybe not. I've tried turning Bluetooth off and the Fitbit off. It's just weird that it did get through initially if it's not compatible. Any help would be great .I have a new Moto E5 Play phone.
Best Answer08-27-2018 01:06
08-27-2018 01:06
If your phone is not on the list of supported devices at www.fitbit.com/devices then it can mean one of two things:
Given that you had initial success let's hope it's the latter.
When syncing / connection issues arise (as they do from time to time) it's worth restarting your phone and then restarting your fitbit using this procedure:
You might also try forgetting the fitbit in your phone's bluetooth settings. If it still won't sync after that then there are some more ideas to try in this help file: https://help.fitbit.com/articles/en_US/Help_article/1866/
