07-21-2019
19:15
08:14
07-21-2019
19:15
08:14
For the past week I have not been getting any HR reading or sleep data. I have tried turning the device off/on, charging, cleaning it to no avail. It does track my steps, exercise & calories although I’m not convinced it’s entirely accurate.
07-21-2019 19:30 - edited 07-21-2019 19:32
On your watch, go to the settings app (swipe to the left) and in the settings app scroll down to Heart rate. Ifnit is on, turn it off and restart your Versa and go back and turn it on again. If it is off then turn it on. If neither ofnthese options work please come back here.
Here is a Help Article on the subject Heart rate monitoring problems
Helen | Western Australia
07-22-2019
18:50
08:15
07-22-2019
18:50
08:15
That still did not work. In addition the time is off. It is currently 9:49 pm & the Fit is showing 9:37.
Moderator edit: removed personal information
07-22-2019 23:08
07-22-2019 23:08
I have flagged a moderator to come and help you.
07-23-2019 03:10
07-23-2019 03:10
I am having the same problem and have reset restarted turned off still no green light on back
07-23-2019 08:20 - edited 03-27-2024 06:06
Welcome to the Community Forums @PAPeggy! Thanks for the steps you've tried and following @NellyG's suggestion in order to solve the issue with the heart rate on your Versa.
Since none of the steps you tried have worked, I've created a case to get you in contact with our Support Team about this. They will be able to work with you and review your options. Please keep a lookout in your inbox to the email address associated with this Fitbit account. Someone will be in contact with you soon!
Welcome on board @Mitchellkris! Thanks for already restarting your Versa. Nice way to go!
If your Fitbit device doesn’t show your heart rate, try the following troubleshooting tips in the order shown. After each tip, view your heart rate to see if you solved the problem.
