12-16-2020
14:06
17:24
RicardoFitbit
12-16-2020
14:06
17:24
RicardoFitbit
Versa heart rate has stopped working. Tried restarting, turning heart rate on and off, factory reset, etc... but nothing works. This seems to be a common problem amongst Versa users recently. What is the fix?
01-09-2021 10:27
01-09-2021 10:27
The suggestions have not worked. My Versa 2 was a Christmas present, so it is brand new. Please open a ticket. If this is a known issue will the units be replaced?
01-09-2021 13:39
01-09-2021 13:39
Hello!
I also have had the same issue and tried what you suggested to try and fix it. My light flashes when I take it off my wrist for a court seconds and then goes away. But it has not been tracking working.
01-09-2021
15:49
11:21
DavideFitbit
01-09-2021
15:49
11:21
DavideFitbit
I am having the same issue. My Versa 2 is flashing the green light but my heart rate monitor is not showing any reading.
Please can someone from the CS team help me resolve this?
Thank you
Moderator edit: format
01-09-2021 23:30
01-09-2021 23:30
I'm having the same problem. Fitbit hasn't registered my heartbeat since Dec 5. No flashy lights. I have tried all of the troubleshooting you suggest up to this step. I can't do this step because my Versa only has one button...?
01-14-2021 09:27
01-14-2021 09:27
Hi. I am having this problem as well. My fitbit is about a year old. I have restarted 4 times in the last week and one a factory reset. There are no green flashing lights on the back anymore. All was working fine until about 3 weeks ago and now it isn't recording my heart rate at all, or an accurate burn when I am exercising.
01-18-2021 12:37
01-18-2021 12:37
01-18-2021 21:46
01-18-2021 21:46
Hi-these are my issues exactly. Tried all the previous suggestions and the factory reset.
HR stopped working 2 days ago, all else is tracking fine.
01-22-2021 20:26
01-22-2021 20:26
Even after the update my heart rate was not working. It seems mysteriously it got turned off. I found under settings on the watch a tab to turn it on.
On the Versa 2 you could try scrolling right to left until you find settings and try that. It worked for me.
01-22-2021 20:46
01-22-2021 20:46
01-24-2021 07:31
01-24-2021 07:31
Hello,
I am also have the same issue with my versa 2. The heart rate froze during a workout and after rebooting it worked for about an hr, then froze again. Now the is no light for tracking at all. Any help is appreciated!
Thanks!
01-25-2021 07:15
01-25-2021 07:15
Hey, I am experiencing the same issues with my Versa. Yes I've read through these threads and yes I have tried restarting it multiple times, cleaning, and doing a factory reset. Nothing has worked, my green lights on the sensor aren't lighting up at all. Can you please help? Thanks.
01-25-2021 08:32
01-25-2021 08:32
Same issues here with my Versa lite it was frozen at 90 and then after trying the trouble shooting tips it doesn’t show anything at all
02-02-2021 18:01
02-02-2021 18:01
Please help, I have a versa and the HR monitor doesn't work anymore. I've factory reset, turned on and off, updated, and cleaned the back. Nothing is bringing the green lights back.
02-03-2021 01:14
02-03-2021 01:14
hi i have already tried but nothing is working
fash light is not working. please suggest
02-06-2021 11:45
02-06-2021 11:45
I have tried everything that has been suggested, and I am still not seeing my heart rate or the flashing lights. What else should I do?
02-06-2021 14:18
02-06-2021 14:18
Me too! It starts again after switching off or rebooting for about 5-10 seconds then freezes and when turn over watch the green light has gone very very dim! So dim only realised in pitch black there was something there! What is the solution?
02-06-2021 14:44
02-06-2021 14:44
Hey everyone , I am experiencing the same issues with my Versa2, sensor light not working at all
but my wife’s lite is working fine.
02-06-2021 19:08
02-06-2021 19:08
I received the versa 2 yesterday (Feb 5th, 2021) and it hasn’t been tracking my heart rate at all. The light is flashing green and it tracked my heart beat when I am holding it directly between my fingers but once it’s in my wrist it just goes to 58bpm. I restarted it 3 times and disconnected it and reconnected... I feel like I made a bad choice purchasing 😞
02-06-2021 19:33
02-06-2021 19:33
02-07-2021 04:15
02-07-2021 04:15
