Versa not tracking my sleep
ANSWERED
I can't get versa to track my sleep. Any suggestions?  I've tried looser and tighter, no luck, shows 2 hours sleep when I have slept over 8 hours.
1 BEST ANSWER
Accepted Solutions
Try setting sleep tracking to sensitive. Login to fitbit account at fitbit.com select settings (cog) select versa scan down to sleep tracking and set to sensitive if on normal
49 REPLIES 49
I’m having the same problem.
Hey @KarenR57 and @Tshoe08, welcome aboard! There are a few scenarios where you might see your sleep pattern (which shows your time asleep, restless, and awake) instead of sleep stages:
  • If you slept in a position that prevented your device from getting a consistent heart-rate reading or wore it too loosely. For best results, wear your device higher on your wrist (about 2-3 finger widths above your wrist bone). The band should feel secure but not too tight.
  • If you used the Begin Sleep Now option in the Fitbit app (instead of simply wearing your device to bed). For more information on automatic sleep tracking, see How do I track my sleep?
  • If you slept for less than 3 hours.
  • If your device’s battery is critically low.
  • Try to restart your Versa
Take a look at it and let me know how it goes!
Heydy | Community Moderator, Fitbit
I rebooted my Versa and now everything is working as it should. Thank you!
Sent from my iPhone
How do you reboot it?🤔
Sent from my Verizon, Samsung Galaxy smartphone
Press the left button and lower right simultaneously
Sent from my iPhone
Thanks! I'll give it a try!
My Versa just stopped tracking sleep. I have re started it a couple of times. Lots of people are complaining about the same problem so it is an issue. You need to replace them. Mine is new I ordered it when it was first announced. I bought it from Fitbit you must have some sort of warranty.
Hey @KarenR57, I hope you are great! Sounds awesome that your Versa is tracking your sleep fine now. I appreciate the update. 😉
@Tshoe08, let's go ahead and try to restart your Versa and let me know how it goes!
@Selsa, welcome aboard my friend! Thanks for restating your Versa. I'd like to know if you already reviewed the factors in the help article: What should I know about sleep stages? Now in regards of Fitbit warranty, this one may vary. Take a look at this link for further information.
Keep me posted guys!
My versa is also not tracking sleep.  I reset it it to stock settings and still nothing ?
Same here! I even called them. They told me what I already knew guess we
are stuck with these expensive watches that don t work. Bummer. I hoped for
more from fit bit
How hard can it be to create an update or at least acknowledge that sleep tracking is having issues?  I had my 20$ Fitbit band I got from Marshall’s that worked perfectly and I upgrade to this for the headaches ?
There is a 33 page thread on this in here that they eventually disabled instead of dealing with the issue. See Here..
My verse isn’t tracking my sleep,  how do I correct the problem?
I am having the same issue and it started all of a sudden.   I've rebooted, tightened, all of it and still shows 1 hour and some minutes but it is not correct.
My Versa stopped tracking sleep several weeks ago and I’ve restarted it twice. It appears as though this issue is effecting a lot of people. Will there be an update?
Hello,
I just switched from the Versa to the Versa Lite.... To say the least, I'm very sad to hear this news about the sleep issues.  I rely very heavily on the sleep information due to my sleep apnea issues.  The app didn't even allow me to edit my sleep times either  places...on the phone.. and now on the laptop.  I HOPE that it logs my sleep tonight.  Time will tell.... 🙂
I’m having the same issue. Worked great for a couple of weeks. This is the second most important reason I wear a Fitbit after steps. Rebooting now but it sounds like there is a bigger issue. What are you doing to correct this, Fitbit?
i tried everything posted and nothing worked. On a long shot i tried switching to my dominate arm from my non-dominate arm. It worked the first night and every night since.  It took some getting "used to" because I have always worn my watch on my non-dominate arm. I hope this suggestion helps.
