03-21-2019
03:09
08:34
AndreaFitbit
03-21-2019
03:09
08:34
AndreaFitbit
One of the main reasons for buying my Versa was to log my sleep. Most days it’s fine but recently it’s not been consistent. It often misses the first few hours of my sleep, which totally messes up my sleep history. It’s not because I’m awake - I normally drop off to to sleep within minutes. I’ve googled the problem and now make sure the Versa is high enough up my wrist and not too tight/not too loose. But i’m still having problems. It missed the first 2 hours of my sleep last night 🙁 Does anyone have any suggestions for what I can try next ?
Moderator Edit: Updated subject for clarity.
03-24-2019 04:08
03-24-2019 04:08
Best Answer03-21-2019 18:12
03-21-2019 18:12
Hi @Sue-in-uk That use to happen to me it would say i had like 3 hours and 22 minutes slept. But i found out that i had senstive sleep on not normal so that could be one reason why it dosent work. The second reason could be you need to sync your fitbit everyday for it to pop up.
Best Answer03-21-2019 18:22
03-21-2019 18:22
Best Answer03-21-2019 19:58
03-21-2019 19:58
Try to restart your Versa (if you haven't done it yet) by pressing and holding the Back and Select buttons (left and bottom right) until you see the Fitbit logo on the screen. Then, monitor your sleep for the next night.
Additionally, please note that the Fitbit app currently has in-app error notifications that provide an explanation for why you aren't receiving Sleep Stages on any given night. This is meant to provide insight into what might be occurring to cause this.The error messages are the following:
Try this
Best Answer03-22-2019 01:53
03-22-2019 01:53
How about setting it to sensitive and testing it out?
Best Answer03-22-2019 10:43
03-22-2019 10:43
Hello @Sue-in-uk, @Kenzibit and @Slatyer, I hope you're doing well, it's great to see you around the Fitbit Community. ![]()
I appreciate your participation in the Forums and for sharing your experience with us. @Slatyer and @Kenzibit thanks for taking the time to post some troubleshooting steps, I'm sure they will be helpful.
@Sue-in-uk, please check the troubleshooting steps posted earlier and if you're still experiencing the same situation, let us know so we can check this further. On the other hand, if the troubleshooting steps help you resolve this situation, please mark the post as a solution. This will be helpful to other members of the Community facing the same issue.
Thanks for your patience and understanding, have a great day!
Best Answer03-22-2019 11:58
03-22-2019 11:58
Best Answer03-23-2019 09:28
03-23-2019 09:28
Hello @Sue-in-uk, I hope you're doing well, thanks for taking the time to reply. ![]()
I appreciate you have come back and for letting us know you will try the troubleshooting steps provided. Please keep us updated in case you need anything else!
Happy stepping.
Best Answer03-24-2019 04:08
03-24-2019 04:08
Best Answer03-25-2019 10:01
03-25-2019 10:01
Hello @Sue-in-uk I hope you're having a great day, thanks for coming back and let us know that your device has been recorded sleep correctly these past few days, I'm very glad!
If anything changes, please let us know, we'll be happy to help. Happy stepping!
Best Answer04-08-2019 08:46
04-08-2019 08:46
I have exactly the same problem. I have only had my Versa for four months but it seems very inconsistent in tracking sleep patterns. There are many times it will break my sleep up into different time periods, and others when it says I didn't go to sleep until 2 or 3 AM when I know I was asleep shortly after 10PM. It often says I sleep only 2 to 4 hours a night when I know that isn't accurate. I have tried resetting and wearing the Versa differently but it is still very inconsistent. One night it will be accurate and the next not. Not impressed so far and will likely not be replacing it with another Fitbit.
04-08-2019 09:11
04-08-2019 09:11
04-09-2019 08:26
04-09-2019 08:26
Best Answer12-22-2019 06:33
12-22-2019 06:33
Versa 2 was working great but December 8th after update not tracking sleep consistently it was but now it only shows an hour here then misses a day I really miss it as that's why I bought this
