09-11-2019
09:57
19:26
SilviaFitbit
09-11-2019
09:57
19:26
SilviaFitbit
I have a fit bit versa. when i first got it tracked my sleep fine. however over the last 2 weeks it has only tracked my basic data and doesn't provide insight as to why. if i reset my fit bit out will track my sleep for that night then return to tracking basic data. i wear it far enough down my wrist that it should be able to catch my heart rate and i know i sleep for more then the need 4 hours. any ideas on how to fix this
09-12-2019 19:34
09-12-2019 19:34
A warm welcome to the Community @mlrussell1. Thanks for the details mentioned and the details you've checked before.
There are a few scenarios where you might see your sleep pattern (which shows your time asleep, restless, and awake) instead of sleep stages. I know you've checked some before but please double check them below:
09-13-2019 14:54
09-13-2019 14:54
So interesting turn off events. the fit bit app this morning showed me my sleep details, slept almost 8 hours, but on the versa it only shows i slept a little over 4 as if it only recorded basic details. im not too worried as long as i can view my details, more curious as to why.
09-18-2019 11:12 - edited 09-18-2019 11:13
Thanks for getting back @mlrussell1. Sorry for the delayed reply.
It's pretty weird that your Versa isn't showing the same sleep information as the one showing in your online Dashboard. I would like you to restart your watch and continue checking if you get the same information in both.
