10-20-2019 07:51
10-20-2019 07:51
Hey - I put my versa on charge two days ago and when I went to put it back on it hadn't charged it's still not charging or turning in I have tried in different plugs in house and nothing - can anyone help with this? Thanks
10-20-2019 15:49 - edited 10-20-2019 15:49
Hi @LaurenDon , try restarting your Versa several times and see if that solves the problem. When not, do a Factory Reset. Probably after two days of charging, your battery is overloaded and heated, in the last case call Customer Support. Regards kuzibri
10-21-2019 09:25
10-21-2019 09:25
@LaurenDon welcome to our Fitbit Community! I'm happy to assist you with your Fitbit Versa since it won't turn on nor take a charge, even though you have tried different plugs.
I'd like you to try the troubleshooting steps that are listed in this help article. This article may contain steps that you already tried but you can skip them and proceed with the rest. After this, charge your watch again for 2-3 hours and see if it comes back to life.
Thank you for your help @SunsetRunner.
I'll be around if any question arises.
