Versa not vibrating with notifications
I've had my Versa for almost a month, and it was working just fine. A few days ago, I noticed it wasn't vibrating with my notifications. If I swipe down on the clock face, it will show me the list of notifications, but it does not vibrate upon receiving them. I have deleted the app, re-downloaded, updated the Versa, repaired, restarted the phone and Versa.. I have messed with the Vibration and notification settings on the Versa, the Fitbit app on my phone, and my actual phone settings. I have tried everything I have seen in forms.
I read something about it not working with the Pixel 3 XL, but it has been working for the past month. It shows that everything is synced correctly (top right corner shows green), and if I open the Fitbit app on my phone, it shows that it regularly syncs and updates my step progress. My Versa is receiving the notifications, but not making me aware of it by vibrating. Is this something anyone else is experiencing?
9 REPLIES 9
Welcome to the Forums @CPaananen.
Thanks for sharing all of those details and letting us know what are all of the steps that you tried to get your Fitbit to work correctly. I will be moving this thread to the Versa board as I think it is better suited for it.
In this case I'd like to ask some questions:
  • Does it vibrate with alarms or in other instances?
  • Are the notifications turned On in the power tray? If so, try turning them off and then on again.
  • Did it vibrate before or has it never vibrated with the notifications?
Look forward to your reply.
Lanuza | Community Moderator
Remember to vote for posts that helped you out! Tired of the same workout music? Try a Podcast! 🙂
I has always vibrated in the past. I have tried turning everything on and
off again. Alarms set on the Versa will vibrate, but not set on my phone
through the clock app. I ended up doing a factory reset on the Versa and
that made it work again.
However, the notifications are not clearing now. I have texts from 2 days
ago that are still visible on the notifications screen, even though I've
tried clearing them, marking them as open, and I've opened them on my phone.
I really loved this watch at first, but after only a month it is having a
lot of issues.
I'm having the same problem don't know what else to do
@magicladyusa hopefully in your case a regular reboot will do. Have you tried pressing and holding the left and bottom right buttons until Fitbit logo flashes?
@CPaananen I do not think it's your tracker per se. It's the app. For whatever reason some old notifications are stuck in the fitbit mobile app notification channel. It happens to me as well. And many other people. Cat Sad Resolution? Reboot of the phone and Versa. Until next time.
Marrrmaduke | Canada
Charge HR, Blaze, Charge 2, Charge 3, Inspire HR, Versa Lite, Versa SE, Aria
Yes I rebooted it then tried to go back to factory settings and then tried to do the firmware update. Right now it won't update. It shouldn't take overnight to update. Now my Fitbit just says no data needs to sync.
@magicladyusa Was the factory reset successful? What is Versa's display showing?
Yes after I removed it from my phone and started all over again. Seems to be working fine now.
Hello @CPaananen and @Marrrmaduke. Welcome to the Forums @magicladyusa.
I apologize for the delay in my response.
@Marrrmaduke Thanks for  being around to help! Greatly appreciated.
@magicladyusa and @CPaananen, Thanks for sharing all of the steps that you tried to get it to work and for letting us know that it seems to be working correctly now. Hopefully it continues to work without any hiccups.
If you have the time, maybe you could visit one of our Discussion boards. There are lots of different topics to talk about with other users so maybe you will find something for you.
Let me know if you have any further questions.
@magicladyusa Glad to hear that! 😄 Happy New Year!
