06-15-2019 07:27 - last edited on 06-16-2019 15:10 by LiliyaFitbit
My Versa started to not sync, then was not keeping the correct time. I tried resetting it using the two button way. No help. After 3 days of trying, I did a factory reset. Now versa will not turn back on. I also tried to hold down all the buttons for over 3 minutes several times. No luck.
12-03-2019 14:47
12-03-2019 14:47
So I've been having a ton of issues with my fitbit, not syncing, battery dying way to fast. So I finally did a factory reset (where you go under the about and hit factory reset), except it didn't work. After the factory reset I got a red X in a circle & under that it read "Data not cleared sync & try again".
Problem is I can't sync it again, I can't seem to do anything now. I also tried, many times, to do the factory reset where you hold all 3 buttons down & then let the bottom right button go once the logo appears. That doesn't work either.
Now I'm sitting here with a $150 watch that does nothing except display a red X in a circle & a message that says "data not cleared sync & try again" How can I fix this issue. Cause if I can't I'm I'm getting a tracker that actually works right.
12-03-2019 14:52
12-03-2019 14:52
Forget it, based off what I've read the fitbit team can't do anything to help. There is clearly a bug in the IOS that was never addressed. I'll never buy fitbit again.
12-11-2019 05:27
12-11-2019 05:27
I Have the same problem. I can't turn on my smart watch - FitBit Versa.
12-17-2019 19:55
12-17-2019 19:55
I have tried everything, also tried hold all 3 buttons for 20 seconds. But Fitbit is not starting, and not showing any logo.
12-20-2019 11:52
12-20-2019 11:52
Hi that is the same thing fitbit customer service did with me they gave me a 25% discount on another fitbit but I will not be buying another one. If they are having that many customer call and complain about the same problem they should be replacing our fitbit versa or giving everyone a refund,I have had my fitbit 15 months and never abused it or gotten it wet it is still in perfect condition but useless now to me im very upset about my fitbit versa.
12-20-2019 21:31
12-20-2019 21:31
I’m having the exact same issue. Time was not being kept. Tried syncing it, didn’t work. Tried updating it, time still didn’t work. Did a factory reset and now the screen is just black. Tried the all three button Method and still nothing. Please advise
12-20-2019 22:00
12-20-2019 22:00
Looks like with the new update to the Fitbit versa if you try to do a factory reset on it it will brick it or 'cuase major issues. Also it seems if you let it drain the batter all of the way down or turn it off it will be difficult to start it up again. Luckily I was able to press all 3 buttons to get it up and running. 25% won't do anything for anyone, either replace it or sell the Lite or Versa 2 for $50.
12-20-2019 22:28
12-20-2019 22:28
I am having the same issues with them 😭 I am so upset I bought it for 300 1 year and 4 months ago I am so upset about their offer !!! We can accept this as a solution
12-20-2019 22:31
12-20-2019 22:31
12-20-2019 22:31
12-20-2019 22:31
I AM EXPERIENCING THIS EXACT FEELING I HAVE RECOMMENDED and advertised fit bit and now I feel so stupid for doing so, I called customer service and they were horrible to me !
12-20-2019 22:33
12-20-2019 22:33
I agree what the hell they need to do right by us we keep them in business ! Have the reached out to you ?
12-20-2019 22:44
12-20-2019 22:44
12-21-2019 04:47
12-21-2019 04:47
My Versa is also completely dead. 3-button method does nothing. 2-button method does nothing. Screen is black and that is it. Please help. I am heart broken as my Versa means a lot to me.
12-21-2019 04:58
12-21-2019 04:58
12-21-2019 09:28
12-21-2019 09:28
For Spencerich92: Not for you to sell at $25, it's for Fitbit to have a better resolution than just providing 25% off a new Versa. It is their fault that the new update has caused problems, so they either provide a replacement or if they expect us to move to the new version than sell the new version to us at a more reasonable price ex: $25-$50.
12-21-2019 11:21
12-21-2019 11:21
12-21-2019 11:26
12-21-2019 11:26
12-21-2019 11:36
12-21-2019 11:36
12-21-2019 11:49
12-21-2019 11:49
12-21-2019 11:51
12-21-2019 11:51
