06-15-2019 07:27 - last edited on 06-16-2019 15:10 by LiliyaFitbit
My Versa started to not sync, then was not keeping the correct time. I tried resetting it using the two button way. No help. After 3 days of trying, I did a factory reset. Now versa will not turn back on. I also tried to hold down all the buttons for over 3 minutes several times. No luck.
12-21-2019 11:54
12-21-2019 11:54
12-21-2019 12:43
12-21-2019 12:43
Well they were really nice and since I only purchased it 90 days ago they’re sending me a new one. They responded with a decent quickness. Especially considering it’s a Saturday.
12-29-2019 18:08
12-29-2019 18:08
I am having this same issue not being able to get my fibit versa to turn on after factory reset, have tried all troubleshooting suggested on this website and nothing works. Very upset wish I had not done a factory reset. What can I do
12-29-2019 18:52
12-29-2019 18:52
Same issue nothing works
12-29-2019 19:39
12-29-2019 19:39
12-29-2019 19:48
12-29-2019 19:48
12-29-2019 19:52
12-29-2019 19:52
Same is happening with mine. It's 18 months old and I was offered a 20% discount off a new item. This is an absolute JOKE since their update killed my device. I won't be purchasing from Fitbit again.
12-29-2019 20:19
12-29-2019 20:19
12-29-2019 20:36
12-30-2019 10:50
12-30-2019 10:50
01-01-2020 03:29
01-01-2020 03:29
It is one thing for the product to fail when out of warranty. It is different when an update from Fitbit causes problems to the point a factory reset is necessary and then that procedure deems the product unusable. I have purchased many fitbit products over the years but this is my last. A $150 watch should last more than 2 years. I've never had any fitbit last longer than that.
01-01-2020 12:24
01-01-2020 12:24
01-01-2020 15:43
01-01-2020 15:43
01-01-2020 16:08
01-01-2020 16:08
01-01-2020 16:17
01-01-2020 16:17
01-14-2020 21:29
01-14-2020 21:29
I’ve just purchased a Fitbit Versa a few weeks ago. Initially it was working fine then the clock started to read incorrectly. So I factory reset the watch and now the phone is off and is completely blank with no Fitbit logo like it is completely dead. I cannot turn it on nothing is showing on the screen it’s completely blank unresponsive. Please let me know what to do.
01-14-2020 21:54 - last edited on 01-22-2020 12:13 by LiliyaFitbit
Contact support directly. With it being within a few weeks of purchase they should send you a new one. When they do, it will only the the watch. No charger, make sure you keep your charger!
01-14-2020 22:14
01-14-2020 22:14
Thank you how do I get hold of support I live in Africa
01-14-2020 23:09
01-14-2020 23:09
01-19-2020 14:38
01-19-2020 14:38
I have tried all the resolutions but I still have blank screen with no response
