05-07-2018 22:17
05-07-2018 22:17
I have downloaded the Fitbit connect app but I can’t get past the set up! I try to add my Versa through the main menu. I login which is fine but then it asks “Which Fitbit tracker are you setting up?” And it gives me the options for everything except ionic, versa, aria 2, and ace. It says regarding those that they are “mobile setup only”. Just hope that isn't true. I live in an area where there is no mobile reception. And Mac is included in the requirements on the package.
Best Answer05-07-2018 23:10
05-07-2018 23:10
They mean setting it through the phone application, the Fitbit setup doesn't go through the provider, it simply binds to your smartphone using Bluetooth technology.
05-07-2018 23:10
