11-02-2019
10:01
09:28
YojanaFitbit
11-02-2019
10:01
09:28
YojanaFitbit
Brightness, screen wake, and Do Not Disturb are "greyed out" on the Versa "Settings"
Moderator edit: Format and subject for clarity.
11-02-2019 10:06
11-02-2019 10:06
Hi @egruss try restarting your device. Which phone and operating system are you using? It helps us to know more about what is going on. Let us know.
11-02-2019
10:22
09:28
YojanaFitbit
11-02-2019
10:22
09:28
YojanaFitbit
Android version 9....moto z3 I did trun off and restart did not help....Brightness, screen wake, and Do Not Disturb Just start today.......
11-02-2019 10:24
11-02-2019 10:24
Which version of the app do you have? Your phone is not on the list of compatible devices click to see
11-02-2019 10:31
11-02-2019 10:31
fitbit version 3.8
11-02-2019 10:33
11-02-2019 10:33
Sounds like it's the phone making the problem. You're able to sync and it's counting your steps?
11-02-2019 10:39
11-02-2019 10:39
sometimes it will not sync i try to sync 3 or 4 times be4 it works and it wont give heart rate 1/2 time it wont Track exercise ( bike }
11-13-2019 09:17
11-13-2019 09:17
I have the same for the Brightness, Always On Display, Do Not Disturb and Screen Wake. I'm sporting a Versa 2 and syncing with a Pixel 2 - and things seem to be syncing beautifully.
11-13-2019 19:15
11-13-2019 19:15
Ahem. I think I know the answer. I took my watch out of sleep mode and, voila, I got all those settings options again.
11-13-2019 19:36
11-13-2019 19:36
I have the same problem, I’ve turned my Fitbit off, turned it back on, still the same. I also had to delete Fitbit from my phone and reinstall it. My Fitbit is still grey on those areas.
gmakk
12-05-2019 00:43
12-05-2019 00:43
@martinwillms Yup, that’s the solution. But it means you can’t use Sleep function without affecting the other functions? Seems like a bug to me.
12-05-2019 00:48
12-05-2019 00:48
Well, actually you can set the other function options before you enable Sleep mode, and then set up sleep mode. Still seems awkward.
01-09-2020 21:57
01-09-2020 21:57
Martin, fabulous!!!
01-11-2020 09:05
01-11-2020 09:05
Yeah nothing is working on it not tracking sleep not tracking bike not monitored any sleep I guess I'm going to get myself a new phone next week thank you all for your help I will keep you informed after I buy the phone
02-10-2020 12:29
02-10-2020 12:29
Thank you this solved my problem
02-18-2020 15:43
02-18-2020 15:43
That fixed mine. Moto G6, android version 9. I just tapped the Sleep Mode to off and all the other settings are bright again. Strange. It worked for a couple of months fine until it "switched" the settings on its own. I also deleted the device and app, then reinstalled both today but it did not clear the problem. I was about to reset Versa 2 back to factory settings and start all over again. Whew. Thank you.
04-25-2020 22:10
04-25-2020 22:10
How do you take it out of sleep mode? That’s greyed out for me too.
05-19-2020 08:36
05-19-2020 08:36
Mine are grayed out as well- seemed to do it on its own...
08-04-2020 10:45
08-04-2020 10:45
Same. Brightness, Always-On Display, Sleep Mode, Do Not Disturb, Screen Wake are all grey and can't be turned on. I've tried everything short of a factory reset. I had other issues that I was able to resolve (many, but not all) by restarting or turning off the fitbit and then back on, or deleting and redownloading the app on my phone (and various other tricks I saw on the forum). But those functions are still not working. This is my second tracker as the screen stopped working on the last one, so they sent me a new one.
08-17-2020 09:25
08-17-2020 09:25
GymCrab... Have anyone been about to help you? Mine is doing same thing... All those are greyed out & I can't change them... I got an update today & now i wish i hadnt done it... Mine stopped working as soon as I did the update. 😤
