02-17-2020 07:50
02-17-2020 07:50
As the title says, this has happened a few times now. I thought that maybe was i was doing some movements my wrist was pushing the button, but not it's not. Changed the face just in case it was a problem with it. The watch just reboot, it keeps my workout progress though but it's annoying when it happens. Any ideas? Thank you
J
02-17-2020 09:17
02-17-2020 09:17
Happened to me too this morning. Really happens pretty often but usually I'm vigilant about looking at the screen to catch it. Not today - got to the end of my hour workout only to discover the black screen. It logged most of the length of my workout in the app, but not the 5K-something steps & 300-something calories burned. I do the same workouts regularly, and I work out every day. Reached out to support & I can't even get them to do a one time adjustment for me.
Their answer is my software was out of date. I finally found this on the app but why don't they send notifications or emails about this? Anyway, just to be safe, keep an eye on your fitbit while exercising. I don't trust it.
02-18-2020 02:21
02-18-2020 02:21
Thanks for the reply, how did you update the software on your watch? When was that exactly? Thanks
J
02-18-2020 08:52
02-18-2020 08:52
I went into the app & clicked on my device. That's where it told me to update - I would have thought I'd get some kind of notification or email or something, it wasn't super obvious. Hope that helps!
02-18-2020 15:02
02-18-2020 15:02
I am having the same problem unfortunately. 😞 Almost always turns off during a workout. I too thought it was something I did or if I hit it, but now it's turning off multiple times a day randomly. Sounds like lots of others are having similar problems. My firmware is up to date. Not sure what's going on. I only got my Versa in December.
02-19-2020 07:15
02-19-2020 07:15
Thanks for the reply but my firmware seems to be up to date.Maybe it's just a bug, I was given the watch (no new) so I can't really complained. The good thing is that it saves the data up to the time it reboots and as I have my music on the watch, the music stops too, so that is my queue to know it is happening. Yes annoying when you are right into a workout, as you have to stop and restart everything, but maybe Fitbit will come with a fix in the next update
J
02-19-2020 10:36
02-19-2020 10:36
Mine has been doing that, too. It happened a week after I updated. Now, its just a brick. Fitbit basically said Im out of luck bc Im out of warranty. They offered me a 25% off coupon, which is what the normal sale price is.
02-20-2020 02:18
02-20-2020 02:18
Sugar, that's sucks
04-08-2020 04:46
04-08-2020 04:46
Update: I found out that the fitbit will stop when a particular song was being played. Since i have removed the song from the playlist, it has not stopped once. Strange but hopefully it may help somebody else
J
