11-10-2019
07:35
06:32
JuanJoFitbit
11-10-2019
07:35
06:32
JuanJoFitbit
Why is my fitbit showing my outgoing text message instead of the incoming one?
11-11-2019 06:31
11-11-2019 06:31
@Anev, welcome to our Fitbit Community! I'm happy to assist you with your Fitbit Versa since it's not receiving incoming text messages.
Please restart your Versa as described in this help article. After this, try turning off the notifications and turn them back on. Finally, monitor your notifications and see if the issue gets fixed.
Keep me posted on the outcome! 😀
Best Answer11-11-2019 07:11
11-11-2019 07:11
I have tried that, intial message comes in from the sender and then goes back to showing my outgoing message.
Best Answer11-12-2019 08:22
11-12-2019 08:22
@Anev, thank you for getting back and trying the steps shared above.
I'd like you to try one more workaround that has been helpful for this type of issues. Please try a factory reset. To do so on your device, open the Settings app > About > Factory Reset or Clear User Data. Sync your device before this in order to avoid losing current data. After this, turn off the notifications again and turn them on.
As a side note, I'd like to know if you have the "Quick Replies" feature enabled. To know more about this, check out this help article.
Looking forward to your response.
