05-01-2018 12:15
05-01-2018 12:15
My VERSA inaccurately reports the temperature on the watch face. Right now, it's reporting 22 degrees celcius, while in the actual weather app that comes installed on the phone, the temperature is reported as 26 degrees. Where in the world is the watch face getting the temperature data if not from the weather app?
05-01-2018 14:23
05-01-2018 14:23
The app on mine only shows the temperature in Fahrenheit, with no visible option to change it.
The Versa weather app also doesn't show any data on the phone, only on the Fitbit.
05-01-2018 14:48
05-01-2018 14:48
I once had the wrong temperature display, and when I checked my phone, the weather app had changed to a city in another state that I had visited, not my actual (location) city
06-19-2018 11:28
06-19-2018 11:28
I just set up my versa yesterday and the display was correct. But when I woke up this morning, the display was incorrect. I checked the weather app on the versa and it was correct for my location, so I like you am wondering where the display on the face is coming from and if there is a way to correct it.
06-19-2018 12:06
06-19-2018 12:06
I found the solution to this. On the fitbit app go to the clock selection and hit contact developer (or creator). From there select the settings button, and you can change the display to reflect the current temp.
05-04-2019 08:58
05-04-2019 08:58
I came back after a 5 year hiatus and Fitbit still cannot get its act together! I’m done. Going to garmin or apple. Follow me!
01-29-2022 08:17
01-29-2022 08:17
So what good is changing it to a different city and state? I want my local weather not a different place.
