01-17-2019
21:38
06:58
MarcoGFitbit
01-17-2019
21:38
06:58
MarcoGFitbit
Bought a versa yesterday and all worked great until this afternoon. Now, when I swipe down from the clock screen to check for notifications, I get a thin red line for a second and then the unit restarts. Swiping down when on data screen takes me back to the clock screen as it should. Have restarted several times but still can't swipe down from the clock face without a restart.
Best Answer01-18-2019 07:02
01-18-2019 07:02
Hello @RossBrick, have a warm welcome to the Fitbit Community, it's great to have you on board. ![]()
I appreciate your participation in the Forums and for sharing your experience with us. I would also like to thank you for letting us know the troubleshooting steps you've tried so far. At this moment, I would like to suggest you to perform a Factory Reset on your Versa:
Factory reset your Fitbit Versa will erase apps and all your personal data from the device, including credit or debit cards you added (on devices that support Fitbit Pay). Make sure you sync your Versa before performing a Factory Reset to avoid losing data.
On your device, open the Settings app > About > Factory Reset or Clear User Data. After that, you will need to set up your Versa as a new device:
I hope this can be helpful, give it a try and let us know in case you need anythign else.
Best Answer01-18-2019 15:54
01-18-2019 15:54
Best Answer10-26-2019 16:06
10-26-2019 16:06
I continue to have this problem too. I have factory reset many times. Unpaired versa from app many times and still have problem. Please help. This is getting frustrated. This started after last software update.
