04-29-2018
17:06
05:56
AlvaroFitbit
04-29-2018
17:06
05:56
AlvaroFitbit
I have had my Fitbit Versa just over two weeks and in that two weeks, it has failed to alarm twice. This morning it alarmed at a time I didn't have set for it to alarm. This is my only major complaint. Anyone else having the same issue? I have set both of these alarms local on the device and not via an app or anything.
07-29-2018 15:03
07-29-2018 15:03
07-29-2018 23:43
07-29-2018 23:43
This 'solution' hasn't worked for my Versa. It has intermittently missed alarms for the last month, ever since purchasing my Versa. I have tried every fix mentioned here, and still suffering inconsistent alarms 😞
07-30-2018 06:36
07-30-2018 06:36
I have to set a new alarm every night for the following morning in order for the alarm to work- and then at times that procedure doesn't work.
07-31-2018 08:46
07-31-2018 08:46
Ha, I thought I just slept through my alarm but I definitely had it fail this afternoon (alarm set for 4pm, no alarm happened) and I came here!
Seems like there's a problem that needs addressing...
08-01-2018 19:22
08-01-2018 19:22
This is NOT a solved problem. I have been having intermittent issues with the alarm NOT going off for several weeks. I have tried all the solutions mentioned. It’ll work one or two days, then it won’t. Should not have to reset the Fitbit or delete/add alarm, or reset to factory specs every two-three days to make the alarm work. I was counting on the Fitbit alarm to let me know when it was time to take a particular medication. I have a reminder on my iPhone, but it’s not always with me around the time I need to take the medication. One of the reasons I bought the Versa.... Please advise.
08-02-2018 05:32
08-02-2018 05:32
So why would fitbit buy pebble and not use their basic features, like a freeken dependable alarm. This is really bad for people that have already past 90 days of purchase and can't return. Glad I sold my Fitbit stock at least.
08-18-2018 04:29
08-18-2018 04:29
Was hoping I was imagining it. Will see if I can get a refund and try a different brand
08-26-2018 05:00
08-26-2018 05:00
Yes second that! It would be great if phone alarms can be synced and detected by versa's silent alarm too! I had a mi band last time and it synced perfectly,, with long silent alarms and ability to snooze and i relied on it so much to wake up every morning.
09-04-2018 13:17
09-04-2018 13:17
This is not resolved Fitbit. Please... I missed the gym again this morning, just wheb I don’t set a phone and a watch alarm because it’s been working it stops. I have to book in at my gym, I’m going to get chucked out for not turning up. I’m really upset your refusing to addrsss this. If the watch for some reason looses connection to pulse during the night and resets the eeed for a code, the alarm
doesnt work. IF I have a shower and forget to renter the code, the alarm doesn’t go off. Please firbit. Fit it.
09-04-2018 14:22
09-04-2018 14:22
09-04-2018 15:29
09-04-2018 15:29
Hey There,
i have done done the exact same as Rayfl, and my alarm has not skipped a beat in the last month.
09-05-2018 07:59
09-05-2018 07:59
This "fix" does NOT work. Why is it taking Fitbit so long to come up with a solution that really works, so that a basic app that comes loaded on the device, actually works, and can be counted on to work? Having an alarm that fails at least once per week, really sucks, and I would have expected more for a device that costs as much as it does, and for a fix after so many months of knowing the app is flawed.
09-14-2018 04:30 - edited 09-14-2018 04:37
Regarding version 32.32.10.15 being an improvement: I'm using this version and still have the same problem - alarm only works approximately 30% of the time. I've been awake waiting for the alarm to go off, so I'm sure it's not working and not just a case of me sleeping through it.
10-07-2018 03:32
10-07-2018 03:32
Recently brought the Versa and the alarm has failed multiple times. Annoying as I work shifts and need a silent alarm so I don't wake up the wife. Seems an issue that has been going on for some time without an actual software fix. I would have thought a problem like this would get sorted asap rather than having to get voted for on a forum before fitbit looks at it. Hopefully the new software update fixes this otherwise I will have to return it and look elsewhere.
11-07-2018 04:49
11-07-2018 04:49
I am so frustrated with this versa. One day it works with notifications the next it doesn't. One minute the alarm works the next it doesnt. Prior to going to bed last night I did a test alarm. It worked but this morning it didn't go off when I needed it to. I dont sleep well because I'm afraid that this won't alarm. Since I get up at 4:45 am I dont want to wake up my husband wth a traditional alarm. I never had these issues with the hr. I spend good money on this and I rely on the alarm. Resetting this daily and even hourly isn't a good solution. Fitbit needs to get a reliable product!!
12-03-2018 15:29
12-03-2018 15:29
I have searched all over the app and find any of the prompts you have mentioned. ????
12-31-2018 11:06
12-31-2018 11:06
@paldrup Welcome! Thanks for being part of our Community! Sorry to hear that you haven't been able to configure the Alarms on the Versa. The Versa has the ability to set alarms directly from the device itself. You can follow these instructions to set the alarms.
Let me know how it goes!
12-31-2018 12:18
12-31-2018 12:18
01-17-2019 03:29
01-17-2019 03:29
I am experiencing intermittent alarm failures. The alarm does go off but 10 minutes late than scheduled. The odd thing so far has been if I set it for time ending in "7" such as this morning it was set for 4:47am and the alarm went off at 4:57am. This has also happened when I set it at 5:07am, and it went off at 5:17am. Setting the alarm at 5:11am (the most common for me) has worked every time though. Regardless there is a critical bug in an extremely simple feature. The alarm was the biggest selling point for me since it doesn't wakeup the rest of my family with Fitbit alarm. Reading through these messages it is shocking to see this issue has been going for so long, as I only purchased mine a month ago. Fitbit why is it such a struggle to fix a bug in such a simple feature? And no, your troubleshooting suggestions are not acceptable for the use of an alarm, it should just work like phones have for the past 10+ years.
12-30-2019 13:01
12-30-2019 13:01
Why can't the sleep alarms be set on the Fitbit ap, like with the Charge2 device?
