04-26-2018
04:41
07:54
AlvaroFitbit
04-26-2018
04:41
07:54
AlvaroFitbit
Weather app has asked me to sync since last evening. Still not working after several sync-ings and a restart. Suggestions or still some bugs?
12-22-2018 19:44
12-22-2018 19:44
@Secrest302 and the app itself is up to date if you check in the fitbit mobile app?
12-26-2018 09:14
12-26-2018 09:14
Same here. How do we fix?
12-26-2018 09:32
12-26-2018 09:32
Rose36619,
I will give the steps for the iPhone. Android should be similiar.
I think the update toggle the permissions off.
12-27-2018 00:28
12-27-2018 00:28
Thank you so much! My weather app is working again! 😀
12-29-2018 14:50
12-29-2018 14:50
We've just switched from Alta HR to a new Versa. After re-installing the app numerous times, restarting both phone & watch, enabling all permissions,weather app still does not work. Versa says "No Location Information" & go to app to set up, etc. which we have attempted. Phone GPS is enabled. The app shows only "current location", no city name. Cannot access any list-nothing shows up. If I try to add a city manually, am only able to enter 1st character successfully, anything additional causes screen to freeze & eventually resets to setup screen. AAARRRRRRGGGGGHHH! Firmware version is 32.331.30.
This appears to be a software bug. Anyone have a fix for this?
01-02-2019 06:47
01-02-2019 06:47
Same problem!
Also have enabled 'Automatic location' on fitbit app (Settings>Advanced Settings>Automatic location) and enabled All-day sync & 'Always connected' & 'Keep-alive Widget' and still nothing. App just crashes the minute you try to manually add a location. Please help!
01-02-2019 09:09
01-02-2019 09:09
Did this problem just start (was the Fitbit working previously), or is this a new setup? Ours is new, and this app has never worked. We're unable to get notifications to work, either, and we've tried two different Versas. Afraid this thing will be going back if we can't find a solution.
01-02-2019 09:16
01-02-2019 09:16
Hi, what you could try to do is:
1. Deinstall the Fitbit app from your phone.
2. Restart your phone and enable BT and WiFi
3. Reinstall Fitbit
4. go to apps - my apps - weather and see what happens when you press the settings icon on the right side.
5. When it says "Current location", sync again with the Versa and look if the weather updates, when not:
6. Press add location and enter the exact data of your location manually in the Search bar. When Fitbit finds it, it will be added underneath your current location. Sync with your Versa and keep fingers crossed. Good luck.
01-02-2019 09:22 - edited 01-02-2019 09:27
The only thing that’s working for me is turning your versa off by holding the left middle button and the lower right side button. Hold until the Fitbit sign shows up and goes away. The shut down your phone, wait about 10 seconds then turn the versa and phone back on. That should fix the problem. Good luck!
i just had to do this process again this morning because my notifications Was not working.
01-02-2019 09:38
01-02-2019 09:38
Unfortunately, this has not helped in our case, nor have any of the suggestions posted previously.
01-02-2019 09:40 - edited 01-02-2019 09:44
Hold the middle button and the lower right side button on your versa until the Fitbit logo shows up and then goes away. Shut down your phone, wait about 10 seconds then hold the middle and lower right side button down on your versa to turn back on and then turn your phone back on. This should take care of it. Go to your weather app on your versa and see its showing now. Good luck!
01-02-2019 09:45
01-02-2019 09:45
Sorry 😐 maybe call customer service and see if they can help.
01-03-2019 02:25
01-03-2019 02:25
@Nola45 Fitbit Versa is new and the weather app hasn't never worked. Strava has also never connected... very frustrating as love the watch but has only half the functionality it should have!
01-07-2019 01:38
01-07-2019 01:38
01-14-2019 10:27
01-14-2019 10:27
For me the same problem, i've also tried to add and search address in the weather app. But nothing shows up.
01-14-2019 12:12
01-14-2019 12:12
@SamuelY uninstall and reinstall Fitbit mobile. SYnc. Open fitbit app, tap on Versa icon, tap on Apps and check if there's an update to Weather just in case. Try setting your location now.
01-15-2019 14:37
01-15-2019 14:37
Alright, I just worked it out
Iphone only (I’m guessing)
•uninstall the Fitbit app on your phone
•reinstall the Fitbit app to you phone
•log back into the Fitbit app using your email and password
•wait for it all to sync back together
•go into the weather app settings
•enter your location
That should work, well it worked for me so I would hope it would work for everyone else
01-23-2019 04:53
01-23-2019 04:53
My weather app isn't working it says to sync my fitbit versa to the app which I have done. I read to add my location manually but I'm not sure how to do that because when I type my location in and hit done the only option to change screens is cancel which removes the location I've typed in.
01-23-2019 05:51
01-23-2019 05:51
01-23-2019 11:44
01-23-2019 11:44
@krisk11 does your Versa sync without issues? When was the last sync? It seems like you need to restore Bluetooth connectivity with your Versa. Reboot your phone and Versa (press and hold the left and bottom right buttons until Fitbit logo flashes). Let me know if this helped.
