09-18-2019
12:24
06:00
JuanJoFitbit
09-18-2019
12:24
06:00
JuanJoFitbit
Hi
My versa initially I used to charge every 4-5 days but from last two months I’m charging every 2-3 days, I took last 8 months back, let me know solution
thank you
09-19-2019 06:00
09-19-2019 06:00
@Srihith_17 welcome to our Fitbit Community! I'm happy to assist you with your Fitbit Versa since its battery is not lasting as long as it should.
I'd like you to try the tips that are listed in this help article. These tips are helpful in order to improve the battery life of your Versa. After this, monitor the battery behavior
Keep me posted on the outcome! 😀
Best Answer09-19-2019 08:11
09-19-2019 08:11
I tried the tips you suggested after my battery slowly deteriorated. Now my battery won't charge at all and my Versa is only 9 months old. I tried to find a way to get it replaced under warranty but the web page takes me in circles - warranty page says to click here to get a return authorization which takes you to a return policy page (no return authorization info) with a link to the warranty policy page that takes me back to where I started.
Best Answer09-21-2019 10:08
09-21-2019 10:08
@nickim00 thank you for joining us in this thread and our Fitbit Community! By the way, I'm sorry for the late response. However, I was able to get in touch with our Support team and was told that you contacted via phone in regards the battery draining issue but there were some connection issues.
Due to this, let me go ahead and forward your case to them so they can investigate further and provide a solution. You will receive an email from them soon.
I'll be around if any question arises.
