07-12-2020 08:29 - edited 07-22-2020 05:09
My Versa's battery use to last 4-5 days, on Monday 5July I did a tracker update as the App kept prompting me to do. After the update i have to charge my Versa EVERY DAY. I have deactivated just about everything and that made no difference. Can I undo the update as having to charge my Versa daily is quite a pain.
07-21-2020 07:09
07-21-2020 07:09
Hi @TwentyTwenty, welcome to our Fitbit Community! I'm sorry to hear that the battery of your Fitbit Versa is draining fast. By the way, thank you for troubleshooting this issue before contacting our forums.
Please make sure that you followed the tips that are listed in this help article. This article may contain tips that you already tried but you can skip them and proceed with the rest. Finally, monitor your watch for the next 24 hours and see if the issue gets fixed.
Keep me posted on the outcome.
Best Answer07-21-2020 09:10
07-21-2020 09:10
Hi @JuanJoFitbit, thanks fot your reply, I have tried the power saving settings and finally decided to factory reset my device to try to set it up without the update. After which it does not power up. I have charged it for 8+ hours, held all buttons in for 3+ minutes and nothing. Don't know what more I can do. I am very sad as this device has become an extension of me and for it to brake because of an update is VERY disappointing
Best Answer07-21-2020 11:03
07-21-2020 11:03
I reported the exact issue and was advised by Customer Support to run a "battery test" and provide my results. The battery was fully charged prior to running the test. I had to synce the device 5-6 per day until the battery drain. After I was to provide Customer Support the results. The battety lasted less than 18hr!!! I have emailed Customer Support TWICE since Su day with my results and requested a follow up- I have received no follow up. NOW, my device has been sitting on the charger for 5 hours and has only charged 27%.
Wait for it! It goes down hill as soon as you start having issues with the battery!!!
Best Answer07-21-2020 11:37
07-21-2020 11:37
That's realy sad @Topper2020. Customer support is pretty much useless from what I have read. I wish I had read the comments about the update before doing the update. My battery also lasted about 18 - 20 hours. Then I read a comment stating a factory reset might fix it, that didn't work!
Best Answer07-21-2020 12:16
07-21-2020 12:16
Best Answer07-22-2020 05:06
07-22-2020 05:06
Got mine in January. Have honestly given up on it- Hope they bring out an update that corrects this for the people who haven't completely lost their devices.
07-22-2020 06:25
07-22-2020 06:25
07-22-2020 06:26
07-22-2020 06:26
The Versa I got last August had the same issues in May after the firmware update. So, they sent me a "new" Versa - I have had it for less than 2 months and yesterday it just up and died in the middle of the day. Battery was at about 75% - I looked down and it was a black screen. Tried to do a reboot, charged it all night, nothing. Just used chat support (which was very quick and easy to get to) - and they're sending me ANOTHER "new" Versa. And now I have 2 dead devices in a drawer. Very frustrating that their quality has vastly diminished over the past 12-24 months.
Best Answer07-22-2020 06:37
07-22-2020 06:37
Glad to hear they are so eager to send out new devices, it's kind of strange that they do not request you to send them the old device though... Good luck, I hope third time will be lucky
Best Answer07-22-2020 06:38
07-22-2020 06:38
Best Answer07-22-2020 06:44
07-22-2020 06:44
Best Answer07-22-2020 07:36
07-22-2020 07:36
Thanks @Topper2020 . Will be contacting them NOW. Hope I come right. Glad you did
