03-31-2019
18:28
07:34
JuanJoFitbit
03-31-2019
18:28
07:34
JuanJoFitbit
My versa holds charge for less than a day. It is only less than two weeks old. I have turned off a lot of features to try to preserve battery life.
03-31-2019 18:33
03-31-2019 18:33
Hi @Hully That is not good. Have you tried restarting your Versa several times? If that doesnt help, do a factory reset (settings app on the watch and scroll down to about). If you continue to have problems after trying those two, then please come back here for further assistance.
Helen | Western Australia
04-02-2019 07:33
04-02-2019 07:33
@Hully Welcome to our Fitbit Community! I'm sorry to hear that your Versa's battery is not lasting as long as it should even though you've made sure to avoid all the features that may drain the battery level faster.
In addition to the restart process that shared my friend @NellyG, please clean the contacts of your Versa and charger with a cotton swab and a little bit of alcohol. This will remove any dust that the contacts accumulate. Finally, monitor the battery's level and see if the issue gets fixed.
Keep @NellyG and me posted on the outcome!
Best Answer04-02-2019 10:43
04-02-2019 10:43
04-04-2019 09:58
04-04-2019 09:58
@Hully I appreciate the time you are taking to monitor your Versa. Please don't hesitate to let me know how the battery behaves.
Hope you have a great day! ![]()
