11-30-2018
15:20
10:30
HeydyF
11-30-2018
15:20
10:30
HeydyF
I'm having to charge my versa twice a day for the past 3 days now. I am a very active person so I know my battery level will not last a full 4 or 5 days but I'm obviously concerned with this not. Nothing has happened out of the ordinary and it's on me at all times except when I have to charge it. I've only had it now for a little over 6 months. So this should be under warranty correct?
11-30-2018 15:22
11-30-2018 15:22
Concerned with this now*
11-30-2018 15:22
11-30-2018 15:22
12-02-2018 10:41
12-02-2018 10:41
THIS is the accepted solution??
"Concerned with this now*"
12-02-2018 15:12
12-02-2018 15:12
Which Clock Face do you use? The size of a Clock Face also determines your battery usage. I use the Classic Clock Face (only 35 kB) and charged my Versa last tuesday evening and it's still on 31% now. Hope this helps. How to get the Classic Face: on your Smartphone, press the Versa watch icon in the upper right corner, choose clock faces and thereafter all clock faces. At the end of the page you will find three choices: analog - digital - classic. Press Classic and the right Clock Face will appear at the top of the list on the left side. Good luck, kindest regards kuzibri
12-02-2018 15:36
12-02-2018 15:36
No, I was correcting a sentence in the post. It accepted it as the solution
12-02-2018 15:40
12-02-2018 15:40
I wish that was the case but my clock face has been the same one since 2 months after I've had it and I've had it for almost 7 months now. It's an analog clock face but it's one of the versas and not one you have to pay for... I'll try it but I fear that it's more than just a clock face choice
12-02-2018 15:51
12-02-2018 15:51
You do not have to pay for this clock face. I would suggest, give it a try and let me know how it works for you. This Clock Face, although 35 kB, has a lot of possibilities, which you will find in the settings once you have installed it. It's also one of the the few that offers the possibility of "display always on". Kindest regards, kuzibri.
P.S. My Versa with this clock face already lasts for more than 5 days, without charging. It's now on 30%.
