05-16-2018
03:53
05:14
AlvaroFitbit
05-16-2018
03:53
05:14
AlvaroFitbit
Well where do I start. It's really bad the custmor service I have had. My versa battery isn't lasting. From one day to two . Days . All I get is charge your fitbit versa . Need charging .by email. I reported it straight away to fitbit custmor service .All I got was maybe u have down loaded to many apps even though I had only a running app running but still my battery had to be charged every other day . I got so many excuses over 2 weeks of calls . It was tranfered to another higher department and I got one email even I replied another 3 times no response from the department. But be aware the battery life does not last more than 1 to 2 days if u use more than 2 fit bit apps . As i was advice what isn't suitable for any one going away or long runs .
05-20-2018 10:42
05-20-2018 10:42
@Hayleyblue50 Welcome to the Fitbit Community! I hope you're doing well! Sorry to hear about your Versa's battery draining quickly. Thank you for following the instructions you got from Support. I was checking what happened and got notified that you have received some additional replies from them so I wanted to know if they were able to help you after your initial post?
I look forward to your reply!
Best Answer05-20-2018 11:17
05-20-2018 11:17
Best Answer11-18-2018 07:08
11-18-2018 07:08
Mine is exactly the same! Lasts a day. I stopped wearing it this weekend and just gave up. I’m not sure where to start in complaining about it. The thing with it is that I use 0 apps and don’t even record exercises. I got it because I liked the display better than the Charge and I’d had my charge for 3 years and it was time for an upgrade. I am regretting getting the Versa rather than a new Charge. I guess I’ll start complaining to customer service and I’m glad to know I’m not alone. If I was using it beyond simply wearing it I might understand the battery but all it does is record my basic data nothing more!
12-04-2018
06:52
08:39
12-04-2018
06:52
08:39
@jcarpenter Welcome! It's great to see you around! Sorry to hear about your Versa's battery draining quickly and for the delay in my reply. Try cleaning the contacts including using cotton with rubbing alcohol then charge it by plugging it for a couple of hours directly to your computer's usb port (try different ports) or use an UL listed usb wall adapter. After this restart your device and see how it behaves.
Keep me posted!
Best Answer12-04-2018 08:27
12-04-2018 08:27
Thanks I’ve done all of these things. It’s been an ongoing thing for a few months now and all the basic things that I would do with any device that is not operating properly has been done. Which includes everything you mentioned and more. It charges and then dies within the day or so. I use no apps. I record no workouts. It records my basic info and then a few times a day I sync it. I would understand the battery drain if I was using all the features but I don’t. I simply purchased this replacement for my charge because I liked the display more not for the smart watch stuff. I regret it!! I would trade the smaller display for the inconvience of having to charge any day! It’s obnoxious and not the product that was advertised
12-25-2018 11:02
12-25-2018 11:02
@jcarpenter thank you for the update and sorry for the late reply. Since the issue persist the best thing to do is letting our Support team know so they can further assist you. You will get an email from them.
Keep me posted!
08-30-2019 16:27
08-30-2019 16:27
Same situation for our two fitbit versa's. In the beginning it did last up to 4 days. Now, about a year later, I am fortunate it lasts 24 hours...not sure what is going on as it used to work wonderfully. Seeing the abundance of others that have had this challenge has got me a bit concerned...Thanks for any assistance in advance :).
Best Answer01-05-2020 09:17
01-05-2020 09:17
I have a new Versa 2 and have the same issue, battery lasts no more than 2 days. I’m not using apps, contacts are fine, it charges fine but needs to be recharged way too soon. Do I have to get this refunded some how and how back to my charge 2? It’s a shame because otherwise I like it very much.
Best Answer04-09-2020 10:52
04-09-2020 10:52
I'm having the same issue my battery only stays charged for about 2 days. I've not added any apps to it, the brightness is on Auto, not sure why it's losing charge so fast. When I first got it it would stay changed 3-4 days now its down to being charged every 2 days. I only charge it if it goes completely dead or if I'm home & its on 5-10% life. What can I do?
Best Answer04-09-2020 11:05
04-09-2020 11:05
I am having the same issues. I got mine in December and it seems like right after I unsubscribed from Fitbit premium I started having issues. It won’t stay charged, the touchscreen doesn’t work and it randomly goes blank and I have to reset it constantly.
04-09-2020 11:27
04-09-2020 11:27
