Versa's battery last 2 days
Please so I have been reading and I too have been having issues with my battery draining after two days.  How can the answer from Fitbit tech service be to turn off all of the things that make it a smart watch to save the battery.  Isn't it just a watch?
1 REPLY 1
@Di526 Welcome! It's great to see you around!
Let me help you with your Versa's battery draining quickly and thank you for troubleshooting this issue. Try cleaning the contacts using cotton with rubbing alcohol then charge it by plugging it for a couple of hours directly to your computer's usb port (try different ports) or use an UL listed usb wall adapter. After this, restart your device and see how it behaves. You can also find additional suggestions here.
Let me know how it goes.
Alvaro | Community Moderator
