Versa's charging level stays at 99% for a long time
I've noticed when charging my Versa, it gets to 99% quite fast but then sits there for a LONG time at 99% before it gets to 100%?  What gives?  Shouldn't take a 1/2 hour or longer to charge that last 1%.
9 REPLIES 9
Hi, tes you're right, the last % takes a long while, but you will never see the message "fully charged".When it shows 100% for about 15 mins, just take it oiut of the charger and put in on your wrist. Mind though that it will show very fast 99% instead of 100. Do not worry about that, this is normal behaviour of the Versa. Mine does the same dan lasts for 5 days on one charge.
That doesn't answer my question though.  Why does it rush to 99% and then sit there forever?  That's the question.  Makes no sense and doesn't seem like "normal" behavior at all.
Hi, eventually it reaches the 100% but still giving the message that's still charging the watch. I think that not getting the message "charged fully" is a measure to prevent overcharging and/or overheating. See some topics on this community from users who left their Versa during, f.i., an entire weekend in the charger and after that the battery was dead.
the hr does that too.  frustrating.
I agree and my biggest worry is: am I ruining the battery by now allowing it to reach the full 100%?
I don't want to lose an extra 2 hours of steps for this reason...
Mine doesn't ever get to 100%!
I just got mine..its sitting at 99% for over an hour now. So I doubt mine does either.
Wish I could get my Versa 2 to hold its charge!
Hi @Lunalily9 - don't worry about charging to 100%, it's quite ok to stop at 99%.
The reason for this behaviour is the way lithium batteries are charged. The current is reduced to almost nothing by the time it gets to 99% so can take a long time if the watch is draining almost as fast as it is being charged.
In addition it will take 15 minutes or more to go the last 1% which you will lose in an hour once you take it off charge.
So spending > 15 minutes to get < 1 hour battery life and not being able to use your watch is pretty much a waste.
What you can try is a sync then do a full Shutdown from watch Settings (About) menu. Wait at least 10 seconds before placing on the charger to restart it and charge it.
