09-05-2019
12:39
09:20
JuanJoFitbit
09-05-2019
12:39
09:20
JuanJoFitbit
When turning on screen starts normal then fades to white, almost transparent. Have restarted device and changed clock faces, which have not helped.
09-05-2019 16:56
09-05-2019 16:56
Hi, did you change your Clock Face to one made by Fitbit itself? If not, do so and restart your Versa several times in a row. If that does not solve your problem, I would suggest to contact Customer Support about this issue, regards kuzibri
09-06-2019 06:32
09-06-2019 06:32
Thank you for your response!! Yes, I did try that and still having same problem. I will contact customer support.
Best Answer09-07-2019 09:15
09-07-2019 09:15
@feelinfroggy I'm sorry for the late response. However, let me welcome you to our Fitbit forums.
I appreciate the time spent trying a restart and changing the clock face before contacting our forums. I would like to follow up and would like to know if you have contacted our Support team as advised @SunsetRunner.
Looking forward to your response! 😀
