05-07-2020
14:01
06:18
JuanJoFitbit
05-07-2020
14:01
06:18
JuanJoFitbit
I haven't used my fitbit for a couple of months but I put it back on charge this afternoon, ready to start using again and the Fitbit logo was still showing on the screen. I took it off charge, to which it then wanted my 4 digit pin. I entered the pin but nothing happened, it had frozen. I left it a minute or so and pressed the lock button. The screen then very slowly changed to the normal clock screen. With that the fitbit logo came back on and nothing would happen again.
I left it for a couple of minutes in the charging cradle and then decided to try and hard reset it. Now I have a black screen, nothing happening at all. It is in the charging cradle again but still nothing is happening.
Sorry for the long post but I want to give as much detail as possible.
05-21-2020 06:18
05-21-2020 06:18
Hi @LadyELF, due to the recent events, I apologize for the delayed response. However, let me welcome you to our Fitbit Community.
Regarding the screen issue that your Fitbit Versa has experienced, I appreciate the time spent trying to get this issue resolved before contacting our forums.
I was able to get in touch with our Support team and was told that they will reply to your email soon in order to follow up and assist you accordingly. Please keep an eye on your email account.
I'll also be around if any question arises.
05-21-2020 06:30
05-21-2020 06:30
Same issue here. Mine died after the update. I tried the restart thing numerous times with no luck. It just went out our warranty a couple of months ago but it was not my fault fitbit released an update that crashed the tracker....any option / response from fitbit for those outside the warranty period given it was not an sure problem?
