12-20-2018
16:54
07:52
LanuzaFitbit
12-20-2018
16:54
07:52
LanuzaFitbit
After following the recommended factory reset instructions for this firmware update, I can no longer get my Versa to show anything other that the above message, Any help would be welcomed
07-13-2020 00:33
07-13-2020 00:33
07-13-2020 00:40
07-13-2020 00:40
Thank you.
I spent over an hr with customer service on chat and finally got it to work.
I still have unresolved notification issues . But that's another story 😅
Best Answer07-13-2020 05:31
07-13-2020 05:31
Best Answer07-15-2020 10:34
07-15-2020 10:34
Same here
Best Answer07-15-2020 10:51
07-15-2020 10:51
Best Answer07-15-2020 13:53
07-15-2020 13:53
I have same issues. Nothing has worked. App does not communicate with phone.
Been 2 weeks now.
Teresa
Best Answer07-15-2020 18:47
07-15-2020 18:47
I have tried all day to figure out how to clear that huge X on my Versa and get it to work. No matter how or what I tried, I couldn't get rid of that X or my watch to work. I tried installing and uninstalling the app a number of times to no avail. After reading a bunch of articles and help on the web, I found that if you remove the device from you fitbit app on your phone or pc, delete it or unpair it. Then force stop the Fitbit app, restart your phone then turn the app back on. It should work at this point. It worked for me, maybe it was just luck? Good luck to you all who has this same issue.
Best Answer07-15-2020 20:47
07-15-2020 20:47
Do you have to WiFi in the app to do the update on your computer?
07-15-2020 22:25
07-15-2020 22:25
Best Answer07-16-2020 10:06
07-16-2020 10:06
I'm not sure about that but I'm assuming it would be much faster for you to update with WiFi.
Best Answer07-16-2020 10:27
07-16-2020 10:27
Best Answer07-17-2020 06:31 - edited 05-06-2024 06:06
