12-20-2018 16:54 - last edited on 12-21-2018 07:52 by LanuzaFitbit
After following the recommended factory reset instructions for this firmware update, I can no longer get my Versa to show anything other that the above message, Any help would be welcomed
12-21-2018 07:56
12-21-2018 07:56
Welcome to the Forums @agentmothman.
Thanks for trying the recommended factory reset and letting us know what is currently going on with the Fitbit.
Maybe you could try to force a restart, not a factory reset, at this point. That should help in case anything is currently stuck with the Fitbit. Then try to run the set up process as if you had a brand new Versa.
Let me know if you have any further questions.
12-21-2018 07:56
12-21-2018 07:56
12-23-2018 17:17
12-23-2018 17:17
This is happening with my Versa as well. The forced reset did nothing. I ended up at the same message. Help!
12-27-2018 16:23
12-27-2018 16:23
I've done as you suggested numerous times now, but still nothing happens. The same messages is showing on the Versa board: "Data not cleared. Sync and try again". Well, I would have if the app found the device!
Started with a Versa that didn't sync and needed to update the software and several hours later I'm stuck with a Versa that doesn't do anything. Anyone found a solution to this problem? I'm guessing I'm not the first nor last to end up with this problem as the software just was updated....
01-01-2019 17:23
01-01-2019 17:23
Hi. I have had the same problem for about 5 days now. I have tried to drain the battery on the device by not charging it but that did not work. I have tried a hard reset as well with no luck. Nothing works. This is my second unit from Fitbit back in September. Please help!
01-06-2019 12:15
01-06-2019 12:15
Welcome to the Forums @banjaradc and @assarsson. Hello @Clcm87.
I apologize for the delay in my response.
There's one more thing we could try to get the Fitbit to work. Please try to follow the steps listed in this help article:
01-06-2019 13:56
01-06-2019 13:56
01-07-2019 07:49
01-07-2019 07:49
01-18-2019 10:42
01-18-2019 10:42
Same for me. Did all recommended that failed .
01-29-2019 12:43
01-29-2019 12:43
I just received my Versa and that is the message that it says right from the get go!! Very frustrating I agree. I am looking for guidance as well.
03-12-2019 05:06
03-12-2019 05:06
None of the steps above worked at all.
I tried everything and still get the same message.
I'm also receiving the following error: The operation couldn't be completed (com.fitbit.HTTP error 500).
I toggled WiFi off and tried again. Same results.
This all happened over night from an update and no my versa is completely useless.
03-12-2019 10:53
03-12-2019 10:53
Hello @SunsetRunner.
Thanks for trying those steps and letting us know that they didn't work.
In this case, do you have access to any other internet connection that you could try? In addition to that I'd like to ask what device is it that you are using to try and sync your Versa.
Look forward to your reply.
03-22-2019 03:19
03-22-2019 03:19
I have tried all of the above. More than once still not fixed. Please help
03-24-2019 10:47
03-24-2019 10:47
Hello @Suzareynolds.
Thanks for trying all of the steps that have been recommended.
In this case I'd like to ask you to provide more details on the situation. What exactly is happening? When did it start happening? When and how did this start happening?
03-27-2019 07:35
03-27-2019 07:35
03-28-2019 11:39
03-28-2019 11:39
Hello @Edusouza92.
Thanks for trying all of those steps to get your Versa to sync again.
I'd like to ask some questions:
04-16-2019 15:06
04-16-2019 15:06
Hello, I am having the same issue. My Fitbit was not vibrating for phone calls and texts suddenly so I tried doing a Reset. Now the only thing thay appears on my Versa is this message with a red X. I have tried a hard restart and still get this message every time. Please help.
04-17-2019 11:43
04-17-2019 11:43
Hello @IJohnson I hope you're doing well, thanks for joining the conversation.
I appreciate you have taken the time to share your experience with us. At this moment I would like to ask you to change the clock-face on your Versa to a Fitbit clock-face and sync your watch. If after changing it, you're still seeing the same error message, please reply to us with a picture of it so we can check this further.
Thanks for your patience and understanding, we'll be waiting to hear from you.
05-22-2019 08:14
05-22-2019 08:14
I see this marked as solved. I have not seen anyone say what fixed their issues. This is my first fit bit and I'm thinking to return it for replacement on day 2... Or find an easier device to work with all together.
Initial pairing went well. My versa could not get decent WiFi so I chose to do software update via Bluetooth. It was painfully slow, but I could see progress bar on phone and watch. At some point I tap watch to wake it and see progress and it was back to square 1... Saying that I need to download app on phone to begin initial pairing. I tried to select the connected Versa from the app and get them to sync or reconnect. It only was successful reconnecting 2x out of a dozen attempts. All other times, I had to delete versa from the app and do an initial pairing again. Only once did this go successfully and it resumed the software update from previous session. However, that only got me to 50% on the progress bar then spontaneously back to square 1. I finally found instructions for factory reset, a trick that only worked once out of many attempts. When it did work, it got me here... Red circle & "X" and message saying Data not cleared sync & try again.
I have tried all suggestions above, none worked. Anything I do on the phone has no effect on the watch at this point. I can't get the factory reset (3 button magic trick) to work either.
05-22-2019 08:18
05-22-2019 08:18
I can assure you that none of the suggestions within this thread fixed the problem.
I called into FitBit and explained the situation. They replaced my Versa with a new one no questions asked.
This error occurred only after 3 months of ownership. It’s very frustrating that something like this can happen and all the suggested fixes do not work.
