Versa says Data not cleared Sync and try again
ANSWERED
After following the recommended factory reset instructions for this firmware update, I can no longer get my Versa to show anything other that the above message, Any help would be welcomed
431 REPLIES 431
Hi, if read my post you could fix your versa lite,  that was I did and my versa is working great, try if no text me to try to help you
Hi,
I'm observing two trends here: people that tried everything to no avail, and people that tried random things and that ended up working. The last procedure I saw just makes no sense: first requires two computers, the second computer seems not to have no Fitbit application installed but the procedure suggests to add the device on it and that ends up working, then try on a phone and it works. It looks like we don't have enough information to solve this issue and we are thus forced to try things blindly. This is the sad result of closed source software and protocols without any diagnostic logging exposed to users. I'm pretty sure Fitbit developers can get diagnostic logging, using undocumented options or even worse, debug builds nobody else has access to. There is little we can do to solve this, as there is a common misunderstanding that opening protocols and improving diagnostic logging will violate IP.
First test fully with one device at a time, making sure the Fitbit is not paired to any other device. If you can turn off Bluetooth on all your devices except the one you are testing the Fitbit on, it is better. Make sure Bluetooth on that tested device is working properly. If you have another Bluetooth device such as a speaker or headphone, try if that still works. If the phone or computer has faulty Bluetooth, there is absolutely no chance the Fitbit will synchronize properly.
Then try to add a new device to your account, select your Versa and follow the steps. If a device already exists, it will offer to replace it and say "yes". If the setup fails, what happens? It can refuse to connect with an error or wait forever to synchronize or install firmware. Long installation is likely caused by the exclusive use of Bluetooth; you need to use wi-fi to setup the Fitbit, but unfortunately, you still need Bluetooth for the Fitbit application to tell the watch about the wi-fi connection.
In my case, my Fitbit stopped working with my phone (error when synchronizing), I cannot figure out why. After a factory reset, I got this insane "data not cleared" message and any attempt to add the device again failed. It appeared non-working in the Fitbit Windows application, but in fact, it was connecting and displaying (on the app) an indication leading me to think it was trying to connect without success. I had to click on the arrow at the bottom of the screen to go to next step, then was asked to setup the wi-fi and the firmware installation went on. That removed the "data not cleared" message and allowed me to use the watch again. But if I try to synchronize with my Android phone, it fails, same error as before this investigation. Trying to add the device again (on my phone) just fails after a few second with a message listing steps to try fix it (steps that never work). If I don't turn off the Bluetooth on my Android phone, synchronization with my Windows laptop fails, even though I unpaired the Fitbit from my phone. Moreover, when I tried with my desktop computer with a Bluetooth dongle, that failed as well to connect; that works only with my laptop offering onboard Bluetooth.
Bottom line, it seems the Fitbit has limited Bluetooth and maybe even wi-fi compatibility with other devices. Some people got luck after returning the watch and getting a replacement one, so maybe some watches work better than others. I agree, that's very irritating and a real waste of time and energy.
It was a bit hit and miss. I installed the fitbit app onto my desktop and attached the cable to it, with the Versa2 inserted into the cradle
Using my phone I retried everything and eventually got to the option of installing an additional device. I can't remember what exactly happened then, but I was reminded that I had an existing device linked to the app. I think I had to switch Bluetooth off and on, matching to versa and the existing device miraculously matched and started updating, which took a few minutes
Hit and miss, as I say
I have tried all the steps above. I tried to sync once and it didn't work. So I deleted my fitbit versa2 from my devices. now I can't sync my device.
Could you please help
I did that several times and even set up a new account. But to get it to
work I connected my Fitbit to my lab top (I kept the Fitbit on the charger
). I deleted it from my phone and then went on the fit bit app on my phone
and set up a new device. I did the update tracker and let it go from there.
It would stop several times but I would hit the update button again and it
picked up where it left off. I would not use my phone and I would not let
the phone dim. I kept the Fitbit sit on my phone and had everything on
chargers. It took awhile but finally got it done. Good luck!
I have tried every single step, and all my efforts have been to no Avail. This is my 2nd versa, I did a factory reset because the device stopped measuring activities.  First the heart rate followed by measuring sleep activity. I am extremely frustrated, and totally disappointed with Fitbit!
I connected my Fitbit to my lab top (I kept the Fitbit on the charger ). I
deleted it from my phone and then went on the fit bit app on my phone and
set up a new device. I did the update tracker and let it go from there. It
the phone dim. I kept the Fitbit sitting on my phone and had everything on
Thanks for the information, I'll give it a try tomorrow. Oh Happy Day!Sent via the Samsung Galaxy S9+, an AT&T 5G Evolution capable smartphone
Have been struggling with this issue since Tuesday. I got the red cross and data not cleared. Tried updating - it was so slow that I left it overnight and still didn't update properly. Have tried all the steps above. Now it is on black screen and won't even charge (the app says it synced on Wednesday but, if so, it didn't update it properly - no stats were recorded from Monday or Tuesday). This morning I got a red 0% but device not charging at all (it was at 100% on Wednesday).
i connected my Fitbit to my lab top (I kept the Fitbit on the charger ). I
Make sure your Fitbit is on the charger cradle correctly. I didn’t have
this issue but I did have the red x.
Thank you. I tried all of those things - none of them worked. And now the
phone won't charge either...
I’m sorry it didn’t work. I know how frustrated you are. It took me days to
get mine done.
Robinson
It's difficult, but it's finally done with the exception of recording the heart rate, and sleep activity. Three basics activities are functional, recording steps, hours today, and the clock; nothing else that the Versa is capable of doing is being displayed, or recorded to the app.Sent via the Samsung Galaxy S9+, an AT&T 5G Evolution capable smartphone
Glad you got it working at least. I hadn’t been wearing mine since it
happened so I don’t know if all the functions are working. Maybe if you
keep working on it, you will be able to figure how yo get the rest working.
Have a great weekend and be safe!
It keeps on telling me that I have to sync and try again!!! What crap!
1.- connect your smartwatch in your computer like if your are going to charge
2.- Wait the pc looking for updates of your device.
3.-  turn off your bluetooth on phone and turn on again.
4 - Open your Fitbit app and add new device, then make the updates show the app for your smartwatch, wait until finished the updates and disconnect your smartwatch when the screen are normal.
Thanks for all your replies. The Fitbit support team has sent me a new pebble. Great service from them considering I live in South Africa!
Stay safe everybody!
The same thing is happening to me, and I tried all the recommended steps.  Please help.
Connect your watch to pc with working wifi. And then the upgrade will
happen. Delete your device from phone and pair again
