12-20-2018
16:54
07:52
LanuzaFitbit
12-20-2018
16:54
07:52
LanuzaFitbit
After following the recommended factory reset instructions for this firmware update, I can no longer get my Versa to show anything other that the above message, Any help would be welcomed
03-31-2020 22:06
03-31-2020 22:06
I did everything but to no avail. I contacted customer support and even they couldn't fix it. They were going to send me a new one but I went on YouTube and figured it out. Here are the steps...
1.Delete the tracker from the app if you haven't already. Delete the app as well.
2.Go to Bluetooth and unpair the Fitbit from your devices; be sure to check your entire list until you find it.
3. Download the Fitbit app once more. Connect the Fitbit to the charger.
4. Add and setup the select the Fitbit.
5. Be sure to select your Wifi network in order to efficiently download/upgrade everything.
Credits to Aarna Creations on YouTube.
04-01-2020 07:46
04-01-2020 07:46
Finally, 5 easy steps and I Versa out of the data error mode. Everything is now functioning with the exception of measuring sleep activities.
Best Answer04-11-2020 02:42
04-11-2020 02:42
i did the same it worked!!!! wow i was worried that in these days when there's curfew lock down how would i return and get replacement. Thanks a lot for writing in detail.
04-11-2020 03:40
04-11-2020 03:40
Best Answer04-11-2020 09:34
04-11-2020 09:34
Best Answer04-12-2020 01:29
04-12-2020 01:29
Hey Everyone. My fitbit Versa never syncs... It has probably synced about 8 times since I bought it in August last year. I factory reset red it now and the screen comes up with 'data not cleared sync and try again'. However, it doesn't sync and if I try and restart it, it just shows up with the same message. I am so frustrated and irritated with this device.
Please help?
Best Answer04-12-2020 16:05
04-12-2020 16:05
Best Answer04-13-2020 00:11
04-13-2020 00:11
I have tried almost every suggestion. Also, if there is a data sync image on my screen, it doesn't let me restart it or anything so not sure what I'm meant to do
04-13-2020 00:13
04-13-2020 00:13
Best Answer04-18-2020 11:06
04-18-2020 11:06
It acts like it works until you have to download the new upgrade that takes hours then after all that wait it says data not cleared. I have the versa and it works fine but have had issues with the versa lite since we got it.
03:26
14:12
04-19-2020
03:26
14:12
mines have the same thing they did the same thing to me but im still trying to get this thing to work i dnt knw what to do at this point im about sick of them they lie to get ur money and when they got u they dnt care i been throw that with everything i had but im nt going to let them get away this this im nt going to stop in to someone help me i have to write them a letter i will becouse i dnt think what they are doing to use is right
Moderator edit: font
Best Answer04-20-2020 19:03
04-20-2020 19:03
04-23-2020 12:42
04-23-2020 12:42
Yesterday my Fitbit came up with data not cleared sunc and try again
I have tried reboot I have checked latest iOS I have tried using a different devise but still my Fitbit Versa lite still says data not cleared sync and try again
so frustrating
Can anyone help please not sure what else to try ☹️
Best Answer04-23-2020 13:53 - last edited on 04-26-2020 19:46 by LiliyaFitbit
I am having the same problem. Please let me know if you figure something out
Best Answer04-23-2020 14:42
04-23-2020 14:42
Connect your Fitbit into you computer ( like is going to charge) do not disconnect from your computer.
Delete your Fitbit from your app on your phone.
Turn Off the bluetooth and turn On
Open your Fitbit app and Add new device
When the app find your Fitbit smartwatch press add immediately you will see is and update available do the update you will see in your smartwatch is making the update wait until finish, when you see normal screen smartwatch you can disconnect from your pc
04-23-2020 23:24
04-23-2020 23:24
I don’t have laptop just an iPad and iPhone 😟
ive tried disconnecting Bluetooth and removing devise
nothing works Getting very frustrated I’ve used Fitbit for many years and not had any problems till I got versa lite
Best Answer04-24-2020 04:25
04-24-2020 04:25
Well go with a friend that have a computer that's the best way to get back your Fitbit . But you can still trying using your phone .
Delete the device from the Fitbit app in your phone ,connect your Fitbit smartwatch to charge, in your phone turn off the bluetooth and turn on again , then add a new device in the Fitbit app, the app will be searching when find it , add it, when you see is an update available do it, good luck.
PD. It's better if you do it connected your Fitbit into a computer.
04-24-2020 06:08
04-24-2020 06:08
Sorry is a serious reply? This is not feasible in the current pandemic
i have already tried your other suggestion which did not work
i am very unhappy that I spent for me a lot of money for a devise that I now cannot use
why is it not working? I do not seem to be alone I. Having problems with Versa lite
04-24-2020 06:17
04-24-2020 06:17
Yes I know I was very frustrated to when I see my smartwatch dosen't work and take me 4 days to fixed ,and frustrated because Fitbit company do mo have customer support, but you can try what I said before, that the way I fixed my smartwatch an I get it back ,until today is working great
04-24-2020 09:49
04-24-2020 09:49
I am so sorry I thought you were a reply from the email I sent to Fitbit!!
so kind of you to try to help
Your tip worked I borrowed a laptop and set it up on my iPad instead of my phone and it worked!
sorry about the previous reply
be interesting to see if Fitbit ever get back to me
thanks again for your help
