12-20-2018
16:54
07:52
LanuzaFitbit
12-20-2018
16:54
07:52
LanuzaFitbit
After following the recommended factory reset instructions for this firmware update, I can no longer get my Versa to show anything other that the above message, Any help would be welcomed
05-09-2020 05:27
05-09-2020 05:27
Best Answer05-09-2020 08:04
05-09-2020 08:04
Best Answer05-09-2020 08:30
05-09-2020 08:30
Listen. I haven’t even had my fitbit for a year and this “data not cleared. sync and try again” message has been up on the screen for 2 months now. I have tried a factory reset, force reset, disconnecting and reconnecting bluetooth and wifi. nothing is working at all and its very frusturating.
Best Answer05-09-2020 17:50
05-09-2020 17:50
Best Answer05-11-2020 03:36
05-11-2020 03:36
Hi
My Fitbit says data not cleared sync and try again. I've tried all that you said and still does not want to work.
Best Answer05-12-2020 01:05
05-12-2020 01:05
I did everything suggested, but nothing happens. The same message appears: data not cleared sync and try again.
The problem is that my Iphone does not even recognize the Versa, so I can’t sync it!
Best Answer05-12-2020 01:42
05-12-2020 01:42
Best Answer05-12-2020 16:15
05-12-2020 16:15
Hello! Did you find a solution? It is very frustrating. I don’t know what to do...
Best Answer05-12-2020 16:26
05-12-2020 16:26
Best Answer05-12-2020 16:30
05-12-2020 16:30
How I can delete the caches from the Fitbit App? I can’t find this option in my Fitbit App.
Best Answer05-12-2020 17:02
05-12-2020 17:02
1.- Connect you Fitbit smartwatch into the USB cradle in your computer, the computer will be looking updates for the device. ( the computer will no find updates for your Fitbit smartwatch, but keep it connected on the computer).
2.- Turn OFF the bluetooth in your smartphone.
3.- Open the Fitbit app.
4.- Turn ON the bluetooth in your smartphone
5.- Go to your account on the Fitbit app
6.- Go to add new device ( the app will ask if you want replacement your device for the new one, press YES )
7.- After the app setup the new device you will see is an update available, do the update.
8.- In the screen on your Fitbit smartwatch you will see is making an update, wait until finished the update and the screen on your Fitbit smartwatch is normal like new.
Hope toy can fixed ,, this is what I did to fix mine.
Best Answer05-12-2020 17:15
05-12-2020 17:15
To delete the caches for Fitbit app go to settings in your phone then go to apps, look for Fitbit app, open it you will see DELETE,,,, CLOSE APP,,,,CLEAR CACHE, just press clear cache to clean the cache on Fitbit app
Best Answer05-12-2020 17:51
05-12-2020 17:51
Best Answer05-12-2020 19:52
05-12-2020 19:52
Thanks for your help. I don’t know if it is a new iphone upgrade, but there is not such option under the Fitbit app. In Settings > General > iPhone Store > Fitbit; is an option to “off load” an to “delete” the app. I tried both, none of them worked. My iPhone resists to “see” the Versa. I wanna cry!!! 😭
Best Answer05-12-2020 23:05
05-12-2020 23:05
Best Answer05-12-2020 23:43
05-12-2020 23:43
Best Answer05-13-2020 04:19
05-13-2020 04:19
Try to install Fitbit app in another device like a tablet or another phone, also is one Fitbit app for a computer. But I recommend try with another device, phone or tablet (no iPhone )
Best Answer05-13-2020 11:05
05-13-2020 11:05
Best Answer05-13-2020 16:28
05-13-2020 16:28
Hi everyone on here who has had this issue. I also have had all the issues (notifications are up to date and it just keeps going and going and won't turn off. Then the red X data not cleared sync and try again). After trolling through all the coms i too was no closer to resolving the issue. I too did all the suggested fixes the FitBit dude said and to be honest it made the issue worse not better. In the end i could not get rid of the error message showing a red X "data not cleared sync and try again". So darn frustrating!
I have however found a fix and my fitbit is back up and working again. What a rigmarole! If you haven't already, try this within the App go to "set up a new device" which automatically removes the current device that has the error message and complete the set up process. After the set up it wouldn't turn on and therefore the APP couldn't find it (i felt defeated at this stage but ) I held the left button and the bottom right until the Fitbit logo appeared (then let go) . Voila! my clock face appeared on the watch and now its working as normal. Phone can now see the device and the watch is not showing any error messages. Yay! I hope this fix hopes someone.
I hope this helps!
Best Answer05-13-2020 16:51
05-13-2020 16:51
1.- Connect your Fitbit smartwatch into a computer on your USB charger cradle. ( your pc will be looking for updates of the device, the pc will no found any update, but do no disconnect from the pc)
3.- Open Fitbit app in your phone
4.- Turn ON the bluetooth in your phone
5.- Go to your account on Fitbit app
6.- Add a new device ( the app will be looking for new device when find the app will ask if you want replace the existing device say yes).
7.- After add the new device you will see is an update available, just do it.
You will see in your smartwatch screen is making an update ,do not disconnect from your pc until finish the update and the smartwatch screen is normal like new.
If do not fixed instal the Fitbit app in a tablet and try again.
Good luck
