12-20-2018 16:54 - last edited on 12-21-2018 07:52 by LanuzaFitbit
After following the recommended factory reset instructions for this firmware update, I can no longer get my Versa to show anything other that the above message, Any help would be welcomed
05-22-2019 08:59
05-22-2019 08:59
I called customer support. They are walking me through some suggestions now. It looks like I am making progress... The watch is now downloading it's software from WiFi.
It may be that our circumstances are different so they working with me before replacing the device... But this was a brand new Versa. It never finished the initial software download. I'm beginning to think the problem was that my phone (Android) screwed up the versa when it goes to power save mode. It sometimes cuts apps that are consuming battery when on standby. It may have screwed up the Fitbit app's ability to talk to the Versa watch.
I'll give a full update for the thread when I'm done here.
06-11-2019 15:01
06-11-2019 15:01
I just fixed this issue that I had with a replacement Versa they sent me. Got the same message. I went into my WiFi settings and selected Forget This Device. Then just restarted the set up process through my app. It recognized my Versa right away and sent a code.
Hope this helps
06-13-2019 06:19
06-13-2019 06:19
My Versa is doing the same thing and after days of trying it still is unusable. Please advise.
06-13-2019 11:44
06-13-2019 11:44
Hello @troutseeker.
Thanks for taking the time to let us know that you are experiencing this same issue.
I could see that you got in touch with our support team that they have been helping you with this situation. I am sure that they will help you get it all working so that you can get back on track.
If you have the time, be sure to visit one of our Discussion boards. Lots of different topics to talk about with other users in there. Maybe something will pique your interest.
Let me know if there is anything else that I can help you with.
06-13-2019 11:48
06-13-2019 11:48
06-13-2019 13:13
06-13-2019 13:13
I have the same issue. Stopped working when I was away and battery charge ran out.
Have the red x with data not cleared sync & try again. Have been trying for days to sort. Followed all advice on here with no joy.
How do i contact the support team
Also on here it does not seem to have instructions for Versa Lite which seems impossible to turn off
06-13-2019 13:17
06-13-2019 13:17
06-13-2019 13:29
06-13-2019 13:29
Is there a UK number
06-13-2019 13:33
06-13-2019 13:33
06-13-2019 13:43
06-13-2019 13:43
06-16-2019 07:34
06-16-2019 07:34
Hello @troutseeker. Welcome to the Forums @27AS.
@troutseeker Thanks for sharing your experience with our support team.
@27AS You can click here to get more details on all of the channels you can use to contact our support team. Having said that, I have reached out to them so that they can get in touch with you via email. Please keep an eye on your email's inbox, spam and trash folders. They will be more than happy to help you out.
Please let me know if there is anything else I can help you out with.
07-29-2019 10:11
07-29-2019 10:11
For me, my Fitbit Versa stopped working while I was standing in a line yesterday. I had my phone in my hand and I was texting. I could feel the vibration on my phone but not on my watch, so I looked down and it was black. When I had the time I tried to do a reset as recommended. That did not work. I tried to do a factory reset as recommended. Now it is stuck on “data not cleared sync and try again” nothing that I have done works. It just keeps flashing the same message.
08-12-2019 18:58
08-12-2019 18:58
i just bought my Versa lite and it will not show me anything on my screen except that " Reset Failed....your data was not cleared. please try again". I do not know what to do.
08-15-2019 14:50
08-15-2019 14:50
I have the same problem. I can't do anything with the watch. I reset it because it wouldn't sync. Now it won't come on other than the X data not cleared. Sync and try again..
08-23-2019 20:53
08-23-2019 20:53
Same here, X and data not cleared, sync and try again. Well, if it would Sync I wouldn't have tried the reset that led to this. Only 2 months old - super frustrated!!!! Obviously this is a huge issue - why won't Fitbit do anything??? Note that my old Garmin still connects just fine - so it isn't an issue with my phone.
08-24-2019 05:29
08-24-2019 05:29
09-08-2019 08:01
09-08-2019 08:01
Hi there, just got my versa lite yesterday. Everything was working ok. Put a different screen saver on. Keeps giving me a code. Shut down and it works. Then lost my sleep app. Followed what was said here. Now it’s stating Data not cleared sync again. I’m unable to do this. Won’t even let me shut down and try again. It comes back on with the same message. WTH. Never had this trouble with the blaze.
09-10-2019 21:24
09-10-2019 21:24
I just got a replacement one and showed up with this issue.. Why is this even a thing. Really?...
09-14-2019 08:49
09-14-2019 08:49
I have the viral light. This no data cleared error started last night for me Friday the 13th full moon. Lol my luck. First I cod not swiped down to see my daily activity. So I thought I would restart. Turned it off by holding down the button for 10 sec. And when I tryed to turn back on. Got this error. I've unpaired restarted phone. And now can not even pair not device found.
09-14-2019 08:56
09-14-2019 08:56
Got error saying
Unable to connect to Versa light. Please make sure your device is powered on and nearby then please try again
