12-20-2018
16:54
07:52
LanuzaFitbit
12-20-2018
16:54
07:52
LanuzaFitbit
After following the recommended factory reset instructions for this firmware update, I can no longer get my Versa to show anything other that the above message, Any help would be welcomed
02-07-2020 11:57
02-07-2020 11:57
Best Answer02-12-2020 21:45
02-12-2020 21:45
when the screen shows the red x, you can’t do anything with the fit bit. It won’t let you change anything or do anything
02-13-2020 01:40
02-13-2020 01:40
Best Answer02-13-2020 02:35
02-13-2020 02:35
02-15-2020 19:50
02-15-2020 19:50
Not sure if this will help but I had factory reset my fitbit versa lite because it wasn’t syncing via the app, long story short, data not cleared sync and try again was coming up on my screen with a red x, after hours of resetting and disconnecting from Bluetooth, I connected the watch from another phone and attempted setup on this other phone, it got to 100% then was turning on/off multiple times, I then plugged the watch with the charger attached into my laptop (macbook pro) and it finally installed whatever current update it needed and the set up of my watch was complete, not sure if this will work for everyone but after trying to fix my watch all day this worked and its back up and running right now!
02-16-2020 12:28
02-16-2020 12:28
I am having the same issue and I have tried everything
Best Answer02-16-2020 13:48
02-16-2020 13:48
Same for me
Best Answer02-16-2020 15:45
02-16-2020 15:45
02-16-2020 16:43
02-16-2020 16:43
02-17-2020 00:01
02-17-2020 00:01
Thanks will try. I was trying all day yesterday and couldn’t focus on anything else 😫
Best Answer02-18-2020 03:54
02-18-2020 03:54
I had the fitbit app open on safari thats about it.
Best Answer02-18-2020 05:04
02-18-2020 05:04
Best Answer02-18-2020 20:25 - edited 02-19-2020 03:05
Oh PJesus! I think this the trick for my son's versa lite!! USB to a computer, not just a power source!!!
Best Answer02-18-2020 22:30
02-18-2020 22:30
Thanks
Best Answer02-18-2020 22:46
02-18-2020 22:46
Best Answer02-19-2020 00:16
02-19-2020 00:16
I’ve powered up an old iPhone. Going to start again from fresh and see what happens. Fingers crossed.
02-19-2020 07:16
02-19-2020 07:16
I am in a loop. Cannot reset versa 2. Stuck on "data not cleared sync & try again." Cannot sync with this on screen. Reset by holding left button until logo appears. Then I get "data not cleared sync & try again." How do I file a warranty claim to get this replaced? Every 48 hours this thing freezes.
02-19-2020 07:34
02-19-2020 07:34
Best Answer02-19-2020 08:19
02-19-2020 08:19
I definitely recommend speaking to customer support, although I fixed mine they still are sending me a replacement! I used the chat option and tweeted them on twitter as well
Best Answer02-19-2020 08:33
02-19-2020 08:33
