10-29-2018 08:24
10-29-2018 08:24
Believe this is because pin may have been entered incorrectly more than 10 times so need to reset via my phone app. Although connected via Bluetooth my phone will also not connect to Versa. No connection no reset. What next course of action?
10-30-2018 03:54
10-30-2018 03:54
There is a message thread on this page called "Can't unlock my Versa", which helped me. I had to disable the attached cards, then go into "device lock" and disable it - good luck:-)
11-02-2018 10:57
11-02-2018 10:57
A warm welcome to the Community @Easyliving and @Janeasilver thanks for stopping by.
I appreciate all the efforts in trying to fix this issue. To unlock your watch with your phone:
Let me know the outcome.
11-03-2018 16:04
11-03-2018 16:04
06-11-2019 15:08
06-11-2019 15:08
It doesn’t work. Device locked states it is blocked. I am unable to change the Pin. I’m so disappointed with this Fitbit that’s its hard to describe.
06-11-2019 15:11
06-11-2019 15:11
It does not work. When I go to Device Lock, it states that it is blocked and does not allow me to change the pin or do anything. I am so disappointed in this Fitbit that it’s hard to express my feelings.
12-25-2019 17:39
12-25-2019 17:39
When I click on the option to reset my pin it says unable to reset try again ?? 🤷🏻:female_sign:
09-05-2020 17:02
09-05-2020 17:02
What happened if you freaked out and deleted the versa of Fitbit. What do you do now???
09-06-2020 16:36
09-06-2020 16:36
09-20-2020 07:13
09-20-2020 07:13
You ever figure it out? I did the same thing 😥
12-03-2020 02:17
12-03-2020 02:17
unlock with your phone Fitbit versa
09-07-2021 14:43
09-07-2021 14:43
I was able to fix this after a 1hr call with customer support.. Your're not going to like the solution.
You have to factory reset your fitbit, which means you will loose everything.
Hold the button on the side until you see the fitbit logo. (Around 10seconds)
Keep holding, once the logo dissappears let go and then re-press and hold the button until you feel a vibration.
The logo should pop back up and white meaning you have successfully reset the device.
Goodluck!
02-15-2022 13:20
02-15-2022 13:20
Hi, which button or buttons did you press, I’ve tried various combos and made the logo flash but no vibrations seem to happen…..
02-15-2022 13:21
02-15-2022 13:21
Hi Alejandra, what do you do if the device is removed from the phone?
03-15-2023 06:39
03-15-2023 06:39
I didn't get the device lock option
