05-05-2018
		20:55
		08:42
			AlejandraFitbit
		05-05-2018
		20:55
		08:42
			AlejandraFitbit
My Versa is only a week old. It was working great until tonight when the screen just went blank. It is syncing with the app and the battery level is fine. It is not cracked and I was not doing anything unusual when it stopped working, just walking around. Any ideas how to fix this?
08-05-2019 05:28
08-05-2019 05:28
I'm currently having this issue. I've been in touch with the support team since it started happening a few days ago. They don't seem to understand the problem I'm having. Just send me a new watch this is ridiculous. Also, please train your support staff better. It's like talking to a child to get them to understand this issue.
 Best Answer08-06-2019 06:58
08-06-2019 06:58
HI,
Ultimately I returned the watch to the retailer I purchased it from. They swapped the watch for a new one. Let the retailer deal with Fit bit.
Good luck
 Best Answer08-06-2019 11:45
08-06-2019 11:45
Smart move! Fitbit won’t fix it
Mine hasn’t worked for over 14 months. My bike app has never been able to calculate my mileage -
The company states they have a team working on it. Hope they don’t pay them much because I ride daily and it never ever has worked correctly I even have a new iPhone to connect it to
 Best Answer08-08-2019 08:13
08-08-2019 08:13
my versa did the same thing. i called customer service and they made me do two different types of resets. i did both and they didn’t work. it ended up being a hardware issue and i got an easy and free replacement through them. i highly recommend contacting customer service with these issues because it only took me ten minutes and i should be getting my new versa in 5-7 businesses days!
 Best Answer08-08-2019 09:08
08-08-2019 09:08
 Best Answer01-19-2020 05:19
01-19-2020 05:19
Holding the button didn't work for me..I see something of a light flicking in the background..but not coming back on. It is fully charged and not cracked nor has it been submerged in water. Any ither suggestions would be helpful my Versa is less than 6months old
 Best Answer03-13-2020 13:43
03-13-2020 13:43
The screen is staying on the logo and nothing else is showing up
 Best Answer03-13-2020 13:46
03-13-2020 13:46
Only logo showing up
 Best Answer03-19-2020 11:30
03-19-2020 11:30
That’s exactly how I feel. They offered to give me 25% off if I purchased a new one☹️😖
 Best Answer03-20-2020 10:54
03-20-2020 10:54
 Best Answer03-27-2020 13:07
03-27-2020 13:07
Update: Fitbit actually sent me a new watch since my watch was under the warranty. I called and complained to the customer service and they mailed me a new Versa 2 of which I've been using now for approximately 2months without issue. If your wat h is new they will replace it..if it's out of warranty I believe they just offer discounts. Good luck to anyone having this issue 🤞🏽
 Best Answer11-02-2020 06:48
11-02-2020 06:48
Hi, I'm having this issue as well. I've tried setting up the device, however, if you can't see the display, you can't get the code that will display on the device.....
 Best Answer11-02-2020 07:14
11-02-2020 07:14
 Best Answer11-02-2020 12:30
11-02-2020 12:30
