02-10-2020 01:17
02-10-2020 01:17
I don’t use my Fitbit in water. I just cleaned it and dry right away if it accidentally had water splashes. I had my device for more that a year now. I’m satisfied with the way it tracks my sleep and activity. Now I can’t even use it coz the cover screen popped up. All the functions are still working tho. Any advice? Is there any repair shop that can get this fixed?
02-10-2020 02:14
02-10-2020 02:14
Unfortunately, Fitbit don't have repair centres. However, if you are in Europe the warranty is 24 months. Either way, it's worth contacting customer support to see if they can help in any way: contact.fitbit.com
Best Answer02-10-2020 10:40
02-10-2020 10:40
If you purchased it using a credit card, check and see if they offer a free extended warranty. My CC has it, never used it, may be worth checking into.
02-10-2020 21:26
02-10-2020 21:26
Best Answer07-07-2020 14:01
07-07-2020 14:01
Mine popped up overnight. I wear to bed all the time. It is a shock. I tried to out it back but it wouldn't stay on. Had to use sticky tape. Some connectivity is lost. Touchscreen is not responding anymore.
Best Answer07-07-2020 23:37
07-07-2020 23:37
@KellyPJ it will also have lost any water resistance it had. It sounds like you'll need to replace it. Hopefully you'll be covered by warranty.
Best Answer07-08-2020 02:36
07-08-2020 02:36
