12-06-2019 14:25
12-06-2019 14:25
Since this last update, 12.06.2019, my watchface will come awake in Gray, then after a second comes back to color. It isn't always consistent but it is annoying. Any thoughts?
12-06-2019 15:13
12-06-2019 15:13
Try a different clock face, preferably a Fitbit one. If that doesn't do it, try a Restart and do it several times if necessary.
 Best Answer12-06-2019 15:13
12-06-2019 15:13
 Best Answer12-13-2019 05:55
12-13-2019 05:55
Thank you. I did change clock faces, although it was sad as I really liked that one. It seemed to be only that clock face had the issue. I did not try to uninstall and reinstall it but I did restart several times and it kept having the problem.
