10-02-2018 11:30
10-02-2018 11:30
10-02-2018 12:09
10-02-2018 12:09
If you read here there have been many problems. You need to contact FitBit support and arrange to have them replace the tracker. It is an ordeal from what I have read here.
10-02-2018 12:10
10-02-2018 12:10
Hi, @TMary, it sounds like your Versa may not be getting a good charge. It may help to clean the charging contacts. More information here. You should also make sure that your charging source is working correctly, amd you should try giving your Versa a restart and repeating the restart procedure at least twice more.
Hopefully cleaning the contacts, checking the charger, and restarting will be enough to get you back going again, but if not do get in touch with Fitbit Customer Support on contact.fitbit.com. Be sure to let them know the trouble shooting steps you have already tried.
Good luck and let us know how it goes. Welcome to the forums!
10-02-2018 12:51
10-02-2018 12:51
thanks so much for your suggestions, will definitely give it a try. trying to get to the setup screen on the Versa is a challenge as the unit doesn't stay on long enough and i cant see whats going on. wish me luck!
M
10-02-2018 12:52
10-02-2018 12:52
thanks for the feedback. will try a couple other suggestions and will definitely reach out to Fitbit for help if none work
M
