11-05-2019
		04:57
		09:12
			JuanJoFitbit
		11-05-2019
		04:57
		09:12
			JuanJoFitbit
I have been noticing the screen on my Versa has colored vertical lines on it, across the entire screen and in the last few days will not hold charge in the battery. It goes from 100% to 0 within a day.
11-05-2019 11:07
11-06-2019 09:11
 Community Moderators ensure that conversations are friendly, factual, and on-topic. We're here to answer questions, escalate bugs, and make sure your voice is heard by the larger Fitbit team.  Learn more
                              11-06-2019 09:11
@klrinne16, it's great to see you in our Fitbit Community. I'm happy to assist you with your Fitbit Versa since it shows colored lines across the screen.
In addition to the restart process that @SunsetRunner shared, try changing the clock face to one developed by Fitbit, not a third party clock face. After this, check out if the colored lines disappear and the issue gets fixed.
Keep @SunsetRunner and me posted on the outcome! 😀
11-08-2019 19:18
11-08-2019 19:18
11-11-2019 07:38
                              11-11-2019 07:38
@klrinne16, I'm sorry for the late response. However, I appreciate the time spent trying the recommended troubleshooting steps.
Regarding the battery draining issue, I'd like you to try the tips that are listed in this help article. These tips are helpful in order to improve the battery life of your Fitbit Versa.
After this, monitor the battery's behavior and see if the issue gets fixed.
Let me know how it goes! 😀
 Best Answer11-12-2019 19:57
11-12-2019 19:57
 Best Answer11-13-2019 09:03
                              11-13-2019 09:03
@klrinne16, thank you for getting back. I was able to get in touch with our Support team and was told that they assisted you via chat and provided some instructions. In case the issue persists, please reply to them with the case number.
Don't hesitate to get back if any question arises.
